Home » Newcomers » Newcomers » adding in java version from C++ version(where is jdt plugin)
adding in java version from C++ version [message #1057918] Thu, 09 May 2013 19:06 Go to next message
sydney faria is currently offline sydney fariaFriend
Member
I currently have the Eclipse C++ version working on my machine, and would like to now add the Java version. The download site shows downloads for the complete Java IDE but I do not see any downloads for just the Java plugin! Or maybe I'm missing something. Any info on how to install the plugin and how to switch between the two plugins once the Java plugin is added would also be of help.
Re: adding in java version from C++ version [message #1057922 is a reply to message #1057918] Thu, 09 May 2013 19:36 Go to previous message
David Wegener is currently offline David WegenerFriend
You install additional plugins using the Help->Install New Software menu item. This allows you to add the Java development tools to the C++ version. You don't need to switch between plugins. They will all be available following the installation.
Previous Topic:'password needed file'
Next Topic:Where is the BIRT 4.2 API?
Current Time: Tue Apr 16 12:01:49 GMT 2024
Powered by FUDForum. Page generated in 0.08408 seconds
