Home » Modeling » EMF » [CDO] Does actually work with PostgreSQL or Oracle?
Re: [CDO] Does actually work with PostgreSQL or Oracle? [message #1057960 is a reply to message #1057855] |
Fri, 10 May 2013 07:27 |
Hi Marc,
CDO is supposed to work with these database systems and it used to do it properly. Then with M6 we came up with an
almost completely new DB framework to address some tricky concurrency issues. This new framework needs adjustments
regarding some of the DB adapters. Your respective feedback is very valuable because we don't have the resources to test
all adapters on Hudson constantly. I'm currently at a conference but will focus on this whole issue with pressure
starting next week. Your cooperation with testing will be highly appreciated ;-)
Cheers
/Eike
http://www.esc-net.de
Am 09.05.2013 12:53, schrieb Marc Gil:
> I'm having serious problems when running a CDO server using PostgreSQL or Oracle. Indeed, it only seems to work with
> MySQL without any problem, in 4.2M6 version.
> I put two bugzillas related with Oracle:
> - https://bugs.eclipse.org/bugs/show_bug.cgi?id=407254
> - https://bugs.eclipse.org/bugs/show_bug.cgi?id=407358
> And another one related with PostgreSQL:
> - https://bugs.eclipse.org/bugs/show_bug.cgi?id=404582
> With the 4.2M5 version of CDO, MySQL, PostgreSQL works perfectly (not Oracle). But since 4.2M6 version, PostgreSQL
> don't work.
> Does anybody achieve to run a CDO server with PostgreSQL or Oracle with 4.2M6 version or later?
> Cheers,
> Marc
Cheers
/Eike
Re: [CDO] Does actually work with PostgreSQL or Oracle? [message #1058102 is a reply to message #1057960] |
Sat, 11 May 2013 10:08 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
On 10-05-13 09:27, Eike Stepper wrote:
> Hi Marc,
> properly. Then with M6 we came up with an almost completely new DB
Hi Eike,
This statement triggers me to think, some relation perhaps with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396743
Which bugs specifically in M6 address the issue you refer to?
thanks Christophe
This new framework
> needs adjustments regarding some of the DB adapters. Your respective
> will focus on this whole issue with pressure starting next week. Your
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi,
>> or Oracle. Indeed, it only seems to work with MySQL without any
>> Oracle). But since 4.2M6 version, PostgreSQL don't work.
>> Cheers,
>> Marc
Current Time: Wed Apr 24 22:14:24 GMT 2024
Powered by FUDForum. Page generated in 0.03674 seconds
