Home » Modeling » EMF » Compare 2 EObjects with that same model(Compare 2 EObjects with that same model)
Compare 2 EObjects with that same model [message #1053777] Tue, 07 May 2013 14:36 Go to next message
Andrew Whelan is currently offline Andrew WhelanFriend
Member
I am looking to compare 2 EObjects. These 2 EObjects are from the same data model. All I am looking for is something (relatively simple) that will return some kind of structure, like the following.
DiffStructure diffObject = EMFDiff.(eObject1, eObject2);
I would then be able to recurse the diffObject to find what has changed from the 1st object (object1) to the second (object2).
Does something close to this exist? EMFCompare seems to compare differences in models? I am looking to compare two EObjects from the same model.
Any information on this will be appreciated.
-Andy
Re: Compare 2 EObjects with that same model [message #1058304 is a reply to message #1053777] Mon, 13 May 2013 14:04 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Andrew,
See the FAQ. Though the code sample uses URIs and Resources to create the comparison scope, you can use plain EObjects instead. All you need is to replace the line
IComparisonScope scope = EMFCompare.createDefaultScope(resourceSet1, resourceSet2);
with
IComparisonScope scope = EMFCompare.createDefaultScope(leftEObject, rightEObject);
Laurent Goubet
Obeo
Previous Topic:[EMF Compare] Using EMF Compare visual diff with files that have .xml extension
Next Topic:[EMF] Get element name of an EObject
Current Time: Tue Apr 16 12:32:42 GMT 2024
Powered by FUDForum. Page generated in 2.11231 seconds
