Re: Problem with emf2java ant script [message #1053754 is a reply to message #1053721] |
Tue, 07 May 2013 13:53 |
Ed Merks Messages: 33137 Registered: July 2009 |
Victor,
Comments below.
On 07/05/2013 3:06 PM, Victor Roy wrote:
> Hello,
> I am having trouble understanding the parameters that go into the
> emf2java ant task, so I am appealing here for help.
> My (simple) ant script is the following:
> <project name="myexample"
> basedir="/Users/vroy/Documents/workspace/myexample">
> <property name="model.dir" value="model"/>
> <target name="generateSources">
> <emf.Ecore2Java model="${model.dir}/example.ecore"
> genModel="${model.dir}/example.genmodel"
> generateModelProject = "true"
> generateEditProject = "true"
> generateEditorProject = "true"
> modelProject="${basedir}"
> modelProjectFragmentPath ="src">
> <arg line="-package http://example.eclipse.org/1.0
> com.demo.emf.example.model example" />
> <arg line="-modelProject
> //Users//vroy//Documents//workspace//com.demo.emf.example.model src"/>
> <arg line="-editProject
> //Users//vroy//Documents//com.demo.emf.example.model.edit src"/>
> <arg line="-editorProject
> //Users//vroy//Documents//com.demo.emf.example.model.editor src"/>
> </emf.Ecore2Java>
> </target>
> </project>
Unfortunately I really don't know much about how Ant works... But my
sense is that if you have an existing already populated *.genmodel then
it will have have all the project folders already specified and they'll
just work...
I found one script that looks like this, so maybe with some kind of
macro thingy you can specify some things only once...
<project default="codegen" basedir="..">
<dirname property="antfile.dir" file="${ant.file}"/>
<!-- Global properties -->
<property name="main.directory" location="${antfile.dir}/.."/>
<property name="output.directory" location="${main.directory}"/>
<property name="source.directory" value="src"/>
<property name="genJDKLevel" value="5.0"/>
<target name="codegen">
<!-- A macrodef makes it easier to generate code for multiple
models in one script. -->
<macrodef name="ecore2Java">
<attribute name="modelName"/>
<element name="settings"/>
<sequential>
<emf.Ecore2Java
model="${main.directory}/model/@{modelName}.ecore"
genModel="${output.directory}/emf/@{modelName}.genmodel"
modelProject="${output.directory}"
modelProjectFragmentPath="${source.directory}"
modelPluginID="@{modelName}.model"
copyright="This is my code."
jdkLevel="${genJDKLevel}">
<settings/>
</emf.Ecore2Java>
</sequential>
</macrodef>
<!-- Generating the code for the library model -->
<ecore2Java modelName="library">
<settings>
<arg line="-package http:///library.ecore org.examples
Library"/>
</settings>
</ecore2Java>
</target>
</project>
> The questions I have are the following:
> a. I want to define the location of the edit and editor projects,
> relative to the model project but this is impossible. If I don't
> define an absolute path in the
> <arg line=... then the projects are created inside the eclipse
> installation folders (on my mac, this means that are created inside
> /Applications/eclipse/Eclipse.app/Contents/MacOS ) no matter what. So,
> how can I define a relative location?
I think you'd need to use some kind of macro substitution in Ant itself.
> b. With the above script, if I try to place the newly created projects
> in my workspace, even with an absolute path I can't. They end up in
> the eclipse's installation folder. Why is this happening? Is there any
> way to fix it?
I don't know about that.
> c. The above script sometimes fails, and I get the following error:
> [emf.Ecore2Java]
> org.eclipse.core.internal.resources.ResourceException: Errors occurred
> while refreshing resources with the local file system.
> [emf.Ecore2Java] at java.lang.Thread.run(Thread.java:722)
> [emf.Ecore2Java] Contains: The project description file (.project) for
> 'com.demo.emf.example.model.edit' is missing. This file contains
> important information about the project. The project will not
> function properly until this file is restored.
> BUILD SUCCESSFUL
> Any idea why?
The generator does not produce .project files. IProjects are only
created when you generate in the IDE the normal way.
> I will appreciate any answers
> Thanks in advance
> V Roy
Ed Merks
FUDForum. Page generated in 0.02843 seconds
