Re: [OCLinEcore][bug?] @pre tag and isPre() method not working properly [message #1053589 is a reply to message #1053569] |
Mon, 06 May 2013 15:58 |
Ed Willink Messages: 7655 Registered: July 2009 |
HI
QVTr 'top' was definitely a bug.
@pre is similar and easily fixed for properties, a bit harder for
operations. (Should be fixed in M7).
But I recently started thinking about implementing @pre evaluation and
realised that while for many examples it is trivial, in the general case
it is necessary to make a complete copy of the system state!
Ed Willink
On 06/05/2013 15:46, Tiago Guimarães wrote:
> When using the isPre() method of
> org.eclipse.ocl.examples.pivot.PropertyCallExp, the returned boolean
> is always false.
> I have also noted that if a add a @pre using the OCLinEcore editor,it
> does not produce an error, but the tag is not stored in the ecore.
> This makes me think that, the tag is being parsed but it is not being
> processed(saved)
> This might be the same bug that QVTrelations had(top not being copied
> from CST to AST)
> Best,
> Tiago Guimarães
Re: [OCLinEcore][bug?] @pre tag and isPre() method not working properly [message #1058055 is a reply to message #1057982] |
Fri, 10 May 2013 16:30 |
If you're using the Pivot model for your own purposes, you need to note
that some increased UML alignments in M7.
Removed:
NamedElement.ownedRule
Added:
Namespace.ownedRule - not used might be removed
Type.ownedInvariants
Operation.preconditions, postconditions, bodyExpression
Property.defaultExpression
There will be further minor changes for UML alignment and
auto-generation appears after Kepler.
Ed Willink
On 10/05/2013 11:29, Tiago Guimarães wrote:
> Oh, just found my mistake...
> I'm running in standalone, and I updated the Eclipse plug-in but did
> not change the jar being used in the build path, so it was still using
> the old version jar.(That's why the editor was working, but the api
> wasn't)
> Sorry about your lost time,
> Tiago Guimarães
FUDForum. Page generated in 0.02651 seconds
