Home » Modeling » TMF (Xtext) » Error with ParseHelper in Test xbase compiler(@Inject ParseHelper<Object is the top level of my tree> parseHelper;)
Error with ParseHelper in Test xbase compiler [message #1052412] Tue, 30 April 2013 03:38 Go to next message
Yoandri Saavedra is currently offline Yoandri SaavedraFriend
I can try with the example in http://www.eclipse.org/forums/index.php/mv/msg/332117/847490/#msg_847490 , I inject with
@Inject ParseHelper<Top Level of my tree> parseHelper;
, but when I try
Model m = parseHelper.parse(model);
... fatal Embarrassed .. this is my error Log..
at cu.ltunas.vlenin.je.ui.jEEjecutableExtension.execute(jEEjecutableExtension.java:309)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Error with ParseHelper in Test xbase compiler [message #1052495 is a reply to message #1052412] Tue, 30 April 2013 06:44 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
http://koehnlein.blogspot.de/2012/11/xtext-tip-how-do-i-get-guice-injector.html
Twitter : @chrdietrich
Re: Error with ParseHelper in Test xbase compiler [message #1052512 is a reply to message #1052495] Tue, 30 April 2013 07:18 Go to previous messageGo to next message
may the problem is that you use e4s injector and not guice
http://www.eclipse.org/forums/index.php/m/809959/
Re: Error with ParseHelper in Test xbase compiler [message #1053365 is a reply to message #1052512] Sat, 04 May 2013 15:51 Go to previous message
Thank very much.. with
GOActivator.getInstance().getInjector("org.example.go.GO").injectMembers(this);
every good..thanks
Previous Topic:Access Restriction
Next Topic:How I can get the contents of my DSL file
Current Time: Tue Apr 16 18:05:23 GMT 2024
Powered by FUDForum. Page generated in 1.25851 seconds
