Re: Trouble getting eclipse to run [message #1052049 is a reply to message #1051717] |
Mon, 29 April 2013 14:52 |
On 4/29/2013 8:01 AM, SpottedTowhee Cooper wrote:
> I installed Elipse and tried to run then got an error: JER or JDK must
> be available. No Jvm was found in the path. I also have a folder named
> sdk as well as the SDK Manager. Is the file that I need in the sdk
> folder? can the SDK Manager help me with this problem?
> The runtime searched for a path that included jre\bin\javaw.exe. Please
> help me to get started.
> Thanks
If you're going to do Java development, you'll need to download a proper
JDK and see http://wiki.eclipse.org/Eclipse.ini for how to point at it
from eclipse.ini.
If you're not going to do Java development, you should be able to point
eclipse.ini at whatever JRE you happen to have on your computer.
FUDForum. Page generated in 0.08138 seconds
