Home » Language IDEs » AJDT » can't create class
can't create class [message #1051301] Sun, 28 April 2013 15:07 Go to next message
nguyen huu son is currently offline nguyen huu sonFriend
Hello
I just start study programing in java
I am trying to create a class in elipse 1.5 but when I finish create and it show me "Could not open the editor: Group not found: show.ext"
hope anyone can help me Sad
  • Attachment: hinh.png
    (Size: 140.00KB, Downloaded 426 times)
Re: can't create class [message #1051460 is a reply to message #1051301] Sun, 28 April 2013 20:57 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew EisenbergFriend
Click on the details button and copy/paste the stack trace here. Also, go into the error log and paste any relevant errors: Window -> Show view -> Other -> Error log.
Re: can't create class [message #1051640 is a reply to message #1051301] Mon, 29 April 2013 03:52 Go to previous messageGo to next message
when I click on detail and it show me
java.lang.IllegalArgumentException: Group not found: show.ext
at org.eclipse.jface.action.ContributionManager.addToGroup(ContributionManager.java:131)
at org.eclipse.jface.action.ContributionManager.appendToGroup(ContributionManager.java:145)
at org.eclipse.jface.action.SubContributionManager.appendToGroup(SubContributionManager.java:82)
at org.eclipse.jface.action.SubContributionManager.appendToGroup(SubContributionManager.java:73)
at org.eclipse.jdt.internal.ui.javaeditor.BasicJavaEditorActionContributor.contributeToMenu(BasicJavaEditorActionContributor.java:156)
at org.eclipse.jdt.internal.ui.javaeditor.BasicCompilationUnitEditorActionContributor.contributeToMenu(BasicCompilationUnitEditorActionContributor.java:107)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditorActionContributor.contributeToMenu(CompilationUnitEditorActionContributor.java:48)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:167)
at org.eclipse.ui.part.EditorActionBarContributor.init(EditorActionBarContributor.java:146)
at org.eclipse.jdt.internal.ui.javaeditor.BasicJavaEditorActionContributor.init(BasicJavaEditorActionContributor.java:127)
at org.eclipse.jdt.internal.ui.javaeditor.BasicCompilationUnitEditorActionContributor.init(BasicCompilationUnitEditorActionContributor.java:179)
at org.eclipse.ui.internal.EditorManager.createEditorActionBars(EditorManager.java:323)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:790)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(EditorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(EditorManager.java:1429)
at org.eclipse.ui.internal.EditorManager$5.runWithException(EditorManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbench.java:1567)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.epf.rcp.ui.MainApplication.createWorkbenchAdvisor(MainApplication.java:116)
at org.eclipse.epf.rcp.ui.MainApplication.start(MainApplication.java:82)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
Re: can't create class [message #1051643 is a reply to message #1051640] Mon, 29 April 2013 03:56 Go to previous messageGo to next message
OK. That error message indicates that something went wrong earlier in the startup. Can you look at your error log as described above?
Re: can't create class [message #1051885 is a reply to message #1051643] Mon, 29 April 2013 10:21 Go to previous messageGo to next message
I tried to open this box but I can't see it @@
Re: can't create class [message #1052047 is a reply to message #1051885] Mon, 29 April 2013 14:55 Go to previous message
Well, I don't know what is wrong, but it looks like your installation is somehow broken. I'd recommend deleting your existing install of Eclipse and unzipping a new one.
Previous Topic:problem with eclipse
Next Topic:A simple parametrized class question
Current Time: Sat Jan 16 22:04:09 GMT 2021
Powered by FUDForum. Page generated in 0.02773 seconds
