Home » Modeling » EMF » [EMF Compare] Using EMF Compare visual diff with files that have .xml extension([EMF Compare] Using EMF Compare visual diff with files that have .xml extension)
[EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1051120] Sun, 28 April 2013 08:20 Go to next message
Bruce Trask is currently offline Bruce TraskFriend
Member
I have two instance models based on an ecore definition. These models are stored in files with an .xml extension. I want to compare them using EMF Compare visual view not textualt view. Using the team api, compare with... I always get textual comparison and not EMF compare visual comparison at the model level. I have entered *.xml in the EMF Compare content type in the eclipse preferences page but the .xml files still are always compared textually. How can I tell EMF Compare to show the model diff between two ecore instance models that are stored in files that have .xml extension.
Thanks in advance,
Bruce
[Updated on: Sun, 28 April 2013 08:41]
Report message to a moderator
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1051866 is a reply to message #1051120] Mon, 29 April 2013 09:55 Go to previous messageGo to next message
Mikael Barbero is currently offline Mikael BarberoFriend
Member
Hi Bruce,
I'm afraid you will not be able to compare XML files with .xml extension through EMF Compare visual editor. The issue is that Eclipse Team/Compare (the framework on which EMF Compare is built on) only ask for the "preferred" content type (and its base types) of its input and not for all matching content types and all of their base types. In your case, as the *.xml extension is registered by the Eclipse platform toward XML Content type, the preferred content type will always be the xml one...
I suggest to use your own file extension to override this Eclipse limitation and raise a bug towards Eclipse Team/Compare (https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform component=Compare).
Hope this helps.
Mikael Barbero
Obeo
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1053667 is a reply to message #1051866] Tue, 07 May 2013 08:12 Go to previous messageGo to next message
Member
Hi Mikael,
Thanks for your reply. I am restricted for the moment for various reasons with the .xml extension. I am ok to modify the team/compare plugins to allow the emf compare editor to come up but I am looking into how and where to do that. I am ok with even a temporary hack solution. Do you have any tips on the easiest place to make such a change?
Bruce
[Updated on: Wed, 08 May 2013 11:43]
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1055820 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
I was able to get the EMF Compare editor to come up with .xml files by the use of some extension points.
<extension point = "org.eclipse.compare.contentViewers">
<viewer
id="org.eclipse.emf.compare.ui.viewer.content.ParameterizedContentMergeViewer1"
class="org.eclipse.emf.compare.ui.viewer.content.ParameterizedContentMergeViewerCreator"
extensions="xml"
</extension>
<viewer
id="org.eclipse.emf.compare.ui.viewer.content.ParameterizedStructureMergeViewer1"
class="org.eclipse.emf.compare.ui.viewer.structure.ParameterizedStructureMergeViewerCreator"
extensions="xml"
</extension>
<extension point = "org.eclipse.compare.contentMergeViewers">
<viewer
id="org.eclipse.emf.compare.ui.viewer.content.ParameterizedContentMergeViewer2"
extensions="xml"
label="Model Diff Compare"
<viewer
class="org.eclipse.compare.internal.TextMergeViewerCreator"
extensions="txt"
id="org.eclipse.compare.TextMergeViewerCreator"
label="Text Compare">
</viewer>
</extension>
<extension point = "org.eclipse.compare.structureCreators">
<structureCreator
id="org.eclipse.emf.compare.ui.viewer.content.ParameterizedStructuralMergeViewer3"
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1055960 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1055977 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
I was able to get the *.xml resources to use the EMF Compare views by adding some extension points:
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056039 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056120 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056121 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056205 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056206 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056291 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056292 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056379 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056380 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056468 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056469 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056560 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056561 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056655 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056656 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056751 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056752 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056849 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056850 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056950 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1056951 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057051 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057052 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057156 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057157 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057260 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057261 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057365 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057366 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057471 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057472 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057583 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057584 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057692 is a reply to message #1053667] Wed, 08 May 2013 11:01 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1057693 is a reply to message #1053667] Wed, 08 May 2013 11:12 Go to previous messageGo to next message
Member
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
</extension>
<viewer
extensions="xml"
<viewer
extensions="txt"
</viewer>
</extension>
<structureCreator
extensions="xml"
</extension>
Re: [EMF Compare] Using EMF Compare visual diff with files that have .xml extension [message #1058302 is a reply to message #1055977] Mon, 13 May 2013 14:01 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Bruce,
I hope all of these messages were duplicates of each other, I don't plan on reading them all to check if the xml changes Razz.
I just wanted to mention that you should be able to compare any model, whatever its extension, through EMF Compare by just adding said extension to the "EMF Compare" content type's list. The wiki is not up to date, but follow the instructions from the FAQ while using the "EMF Compare" type instead of "XML Metadata Interchange (XMI)".
Laurent Goubet
Obeo
Previous Topic:[CDO] Does actually work with PostgreSQL or Oracle?
Next Topic:Compare 2 EObjects with that same model
Current Time: Fri Mar 29 07:48:29 GMT 2024
Powered by FUDForum. Page generated in 0.09348 seconds
