popup property dialog for each component? [message #155540] |
Tue, 26 October 2004 05:33  |
Originally posted by: grayzhu.yahoo.com
My GEF application is based on the logic example.
One thing I wanted to do is editing the property of each graphical component
by popping up a dialog after a doubleclick. I'd appreciate some pointers or
examples for this.
An alternative is using the property view, but it uses "static" blocks to
define the descriptor. I am not sure how to put an array or vector in
property view, and the number of elements can change in run time. One
analogy would be, a OR gate has more the two inputs, and the inputs could be
added during run time, how do I represent the inputs in property view?
Re: popup property dialog for each component? [message #155711 is a reply to message #155540] |
Tue, 26 October 2004 15:15   |
Look at REQ_OPEN which is sent on double-click and ENTER.
"ray zhu" <grayzhu@yahoo.com> wrote in message
news:clkn88$4je$1@eclipse.org...
component
or
> examples for this.
That's just how our implementation works. Your implementation can
dynamically calculate the propertydescriptors at the time it is queried. I
considered your use case as one of the requirements when designing
IPropertySource and PropertySheetEntry.
be
Re: popup property dialog for each component? [message #156199 is a reply to message #155711] |
Sat, 30 October 2004 17:45   |
Thanks Randy for the information
REQ_OPEN is an excellent idea.
But I am still confused about the propertydescriptors approach. As you know
I wanted to list dynamic array elements as keys in property view, each
element in an array is a key, and the number of keys could change. The
reason is that the array contains object references, using the elements as
keys allows me the expand further into sub-object properties. Because
propertydescriptors are defined to be static and created with the class not
the instance, I am not sure how to dynamically calculate the
propertydescriptors, they are list of "keys" in property view as opposed to
values.
Could you be more specific about creating dynamic property? Thanks a lot!
-Ray
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cllpc6$f1r$1@eclipse.org...
> component
> or
> > examples for this.
to
I
could
> be
Re: popup property dialog for each component? [message #156215 is a reply to message #156199] |
Sun, 31 October 2004 16:29  |
Originally posted by: dyx.gmx.net
But do the descriptors have to be declared as static?
> But I am still confused about the propertydescriptors approach. As you=
> know
> I wanted to list dynamic array elements as keys in property view, each=
> element in an array is a key, and the number of keys could change. The=
> reason is that the array contains object references, using the element=
s =
> as
> propertydescriptors are defined to be static and created with the clas=
s =
> not
> propertydescriptors, they are list of "keys" in property view as oppos=
ed =
> to
> values.
> Could you be more specific about creating dynamic property? Thanks a l=
ot!
> -Ray
>> component
>> > by popping up a dialog after a doubleclick. I'd appreciate some =
>> pointers
>> or
>> > examples for this.
>> > An alternative is using the property view, but it uses "static" blo=
cks
> to
>> > define the descriptor. I am not sure how to put an array or vector =
in
>> dynamically calculate the propertydescriptors at the time it is queri=
ed.
> I
>> > property view, and the number of elements can change in run time. O=
ne
>> > analogy would be, a OR gate has more the two inputs, and the inputs=
> could
>> be
>> > added during run time, how do I represent the inputs in property vi=
ew?
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
FUDForum. Page generated in 0.04470 seconds
