Re: [Texo] Generate Table Names [message #1049954 is a reply to message #1049858] |
Fri, 26 April 2013 13:59 |
Hi Bastian,
Maybe a bug... where do you set this maximum sql length? In the annotations model?
It can also be that the annotations model already contains the table names?
gr. Martin
On 04/26/2013 01:09 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> I just created a new orm.xml and wanted the table name to be limited to 30 signs. So I set the "Maximum Sql Name Length"
> to 30. Then I generated the orm.xml, but the table names weren't limited.
> Do I have to set another option, too, in order to get an effect, or is this a bug?
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Generate Table Names [message #1050481 is a reply to message #1049954] |
Sat, 27 April 2013 08:16 |
Hi Bastian,
I tested this just now with an annotations model and with me it worked fine.
gr. Martin
On 04/26/2013 03:59 PM, Martin Taal wrote:
> Hi Bastian,
> gr. Martin
>> Hi Martin,
>> Best regards
>> Bastian
The Netherlands
FUDForum. Page generated in 0.03021 seconds
