Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048396 is a reply to message #1048365] |
Wed, 24 April 2013 12:05 |
Hi Per,
Are you sure that you're using the same CDO version on both clients and server?
Cheers
/Eike
http://www.esc-net.de
Am 24.04.2013 13:07, schrieb Per Sterner:
> I can't specify when it occurs and I can't provide a unit-test. After doing some modifactions, I finally add an item
> to a list (which does not contain the item, it's contained somewhere else).
> After doing the commit I get the exception:
> Caused by: org.eclipse.emf.cdo.common.util.TransportException: java.io.IOException: Illegal type: OBJECT
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:526)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitTransaction(CDOClientProtocol.java:393)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:71)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1178)
> ... 15 more
> Caused by: java.io.IOException: Illegal type: OBJECT
> at org.eclipse.emf.cdo.common.id.CDOIDUtil.read(CDOIDUtil.java:476)
> at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOID(CDODataInputImpl.java:386)
> at org.eclipse.emf.cdo.spi.common.protocol.CDODataInputImpl.readCDOLockState(CDODataInputImpl.java:346)
> at
> org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirmingNewLockStates(CommitTransactionRequest.java:363)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:292)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.confirming(CommitTransactionRequest.java:1)
> at
> org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.confirming(CDOClientRequestWithMonitoring.java:117)
> at org.eclipse.net4j.signal.RequestWithMonitoring.confirming(RequestWithMonitoring.java:171)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
> at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
> at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
> at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
> at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
> at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
> at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
> at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
> ... 18 more
> I am using the current trunk of CDO and everything is running in one Java instance.
> If I remove the 'add' to the list, there is no exception.
> Can somebody give me a clue, what's wrong or how I can debug the problem?
> Regards,
> Per Sterner
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048471 is a reply to message #1048396] |
Wed, 24 April 2013 14:11 |
Per Sterner Messages: 91 Registered: October 2011 |
Member |
Yes, I am really running in one Java-VM (the current CDO and net4j plugins from trunk are in my workspace). I have debugged a lot and it appears, that:
0. transaction.commit(); // I commit my changes
1. CDODataOutputImpl.writeCDOLockState is called and the lockedObject type is CDOID. It's instance is TransactionCommitContext$DeltaLockWrapper$ForID.
2. CDOUtil.write is called and id.getType(); return OBJECT as type and ordinal is 1
[...] Later on:
3. CommitTransactionRequest.confirmingNewLockStates is called
4. readInt() returns 1
5. in.readCDOLockState() is called
6. CDOIDUtil.read is called. ordinal is 1
6. type is OBJECT and causes the exception
[Updated on: Wed, 24 April 2013 14:13] Report message to a moderator
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048481 is a reply to message #1048474] |
Wed, 24 April 2013 14:30 |
Member |
Yes, I looked with 'ss'. All bundles are only runing without a specific date-qualifier.
(I will try it against the current updatesite-dropin)
ss net4j
Framework is launched.
id State Bundle
43 ACTIVE org.eclipse.net4j.db.db2_4.1.0.qualifier
55 ACTIVE org.eclipse.net4j.http.common_4.0.200.qualifier
65 ACTIVE org.eclipse.net4j.db.mysql_4.2.0.qualifier
76 ACTIVE org.eclipse.emf.cdo.net4j_4.1.100.qualifier
95 ACTIVE org.eclipse.net4j.db.postgresql_4.2.0.qualifier
119 ACTIVE org.eclipse.net4j_4.2.0.qualifier
128 ACTIVE org.eclipse.net4j.jvm_4.1.100.qualifier
147 ACTIVE org.eclipse.net4j.db.h2_4.2.0.qualifier
150 ACTIVE org.eclipse.net4j.tcp_4.1.100.qualifier
209 ACTIVE org.eclipse.net4j.http.server_4.0.200.qualifier
226 ACTIVE org.eclipse.emf.cdo.server.net4j_4.1.0.qualifier
238 ACTIVE org.eclipse.net4j.defs_4.0.100.qualifier
249 ACTIVE org.eclipse.net4j.util.defs_4.1.0.qualifier
296 ACTIVE org.eclipse.net4j.db.derby_4.1.0.qualifier
299 ACTIVE org.eclipse.net4j.util_3.3.0.qualifier
309 ACTIVE org.eclipse.net4j.http_4.0.200.qualifier
310 ACTIVE org.eclipse.net4j.db_4.2.0.qualifier
osgi> ss emf.cdo
id State Bundle
2 ACTIVE org.eclipse.emf.cdo.server.admin_4.1.100.qualifier
16 ACTIVE org.eclipse.emf.cdo.security_4.2.0.qualifier
42 ACTIVE org.eclipse.emf.cdo.defs_4.0.100.qualifier
48 ACTIVE org.eclipse.emf.cdo.edit_4.2.0.qualifier
69 ACTIVE org.eclipse.emf.cdo.common.db_3.0.300.qualifier
88 ACTIVE org.eclipse.emf.cdo.server.ocl_4.1.0.qualifier
109 ACTIVE org.eclipse.emf.cdo.transfer.repository_4.2.0.qualifier
114 ACTIVE org.eclipse.emf.cdo.admin_4.1.100.qualifier
116 ACTIVE org.eclipse.emf.cdo.common_4.2.0.qualifier
118 ACTIVE org.eclipse.emf.cdo.server.db_4.2.0.qualifier
126 ACTIVE org.eclipse.emf.cdo.workspace_4.1.100.qualifier
154 ACTIVE org.eclipse.emf.cdo.security.edit_4.2.0.qualifier
172 ACTIVE org.eclipse.emf.cdo.workspace.efs_4.0.100.qualifier
174 ACTIVE org.eclipse.emf.cdo_4.2.0.qualifier
197 ACTIVE org.eclipse.emf.cdo.transfer_4.2.0.qualifier
233 ACTIVE org.eclipse.emf.cdo.transfer.workspace_4.2.0.qualifier
288 ACTIVE org.eclipse.emf.cdo.location_4.0.200.qualifier
306 ACTIVE org.eclipse.emf.cdo.server_4.2.0.qualifier
[Updated on: Wed, 24 April 2013 14:54] Report message to a moderator
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1048543 is a reply to message #1048471] |
Wed, 24 April 2013 16:10 |
Am 24.04.2013 16:11, schrieb Per Sterner:
> Yes, I am really running in one Java-VM. I have debugged a lot and it appears, that:
I've indeed changed something (a lot) about the IDs:
I suggest that you submit a bugzilla and after the JAX conference I'll look at it. Please attach all the infos you've
given here and that may help to reproduce the problem in a test case.
Cheers
/Eike
> [...] Later on:
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1051718 is a reply to message #1049096] |
Mon, 29 April 2013 06:31 |
Am 25.04.2013 13:01, schrieb Per Sterner:
> I noticed that the Legacy Mode is now the preferred option? (http://wiki.eclipse.org/CDO_Legacy_Mode)
Hmm, I wouldn't say so. Now there is no explicit legacy *mode* anymore, or you could say it's always on. But that
doesn't mean that all objects should now be legacy objects. It's just that they're always supported and that there's no
way to exclude them by configuration of the CDOView.
If you have the chance to regenerate your model for CDO I strongly recommend to do it!
> I managed to test against 'emf-cdo-I20130418-0209-Site'. (I had some problems because of EMF v2.7 and the
> 'MinimalEStoreEObjectImpl' retrofit bundle. My Model-Bundle couldn't resolve the class 'MinimalEStoreEObjectImpl')
Similar problems have been reported already and we think that bugs in PDE cause them. At runtime all seems okay with our
retrofit fragment. Does it make a difference for you whether you deploy the retrofit fragment in binary form to the
target platform or in source form to your workspace?
> After adjusting my old genmodel file to use 'EObject' it works with the retrofit bundle :)
Well, in that case the retrofit fragment is not needed at all because your objects are legacy objects (with all their
disadvantages).
Cheers
/Eike
Cheers
/Eike
Re: [CDO] CDOIDUtil.read - Illegal type: OBJECT [message #1052531 is a reply to message #1051954] |
Tue, 30 April 2013 07:52 |
Am 29.04.2013 14:22, schrieb Per Sterner:
> Okay, I adjusted my genmodel.
> I just tried it and it doesn't work for me in any configuration.
> I created some testbundles (not related to anything) and there the same problem occurs. I looked into the section
> "Plug-In Dependencies" and the fragment doesn't appear there. But if I choose "system.bundle" as host-bundle it
> appears in the "Plug-In Dependencies" section and it works. But this doesn't really help :?
> disadvantages).
> My workaround for now is to manually add the MinimalEStoreEObjectImpl class to the org.eclipse.emf.cdo, so it's
> directly visible. Otherwise my model bundle isn't compiled.
I've now explained the problem and possible fixes in https://bugs.eclipse.org/bugs/show_bug.cgi?id=400388#c10
Cheers
/Eike
Cheers
/Eike
FUDForum. Page generated in 0.04655 seconds
