Home » Modeling » Papyrus » EMF transaction for inserting a new Element in a diagram(EMF transaction and papyrus)
EMF transaction for inserting a new Element in a diagram [message #1048264] Wed, 24 April 2013 08:31 Go to next message
HERISSE Alexandre is currently offline HERISSE AlexandreFriend
My question concerns the adding of a Comment or a NamedElement such as a CallBehaviour for example in an active activity diagram through an emf transaction.
I would use the following skeleton for example:
// we suppose we have access to the serviceRegistry instance
TransactionalEditingDomain domain = ServiceUtils.getInstance().getTransactionalEditingDomain(serviceRegistry);
domain.getCommandStack().execute(new RecordingCommand(domain) {
public void doExecute() {
// do the changes here
I have downloaded your Papyrus source code. However I have no idea where to search an example for adding an Element in the active editor or some code that might help me?
I have grep "RecordingCommand" but I found a lot of occurences with some "@generated code" comments. Thus I decided to ask for some help.
How to deal with my need ?
Re: EMF transaction for inserting a new Element in a diagram [message #1048457 is a reply to message #1048264] Wed, 24 April 2013 13:47 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Alexandre,
Many (most?) such editing actions in Papyrus don't execute
RecordingCommands on the CommandStack but AbstractEMFOperations on the
IOperationHistory. They can be added to context menus using the
org.eclipse.ui.menus extension point, together with command handlers.
For an example, you might look at how the Add Child menu is implemented
in the Model Explorer.
HTH,
Christian
> emf transaction.
> Thanks
Re: EMF transaction for inserting a new Element in a diagram [message #1059902 is a reply to message #1048457] Wed, 22 May 2013 07:06 Go to previous messageGo to next message
Hi, I managed to create an EMF object (an initial node) in an activity diagram with this code :
private IElementType getElementTypeToCreate() {
return UMLElementTypes.INITIAL_NODE;
private Command buildCommand()
IElementEditService provider = ElementEditServiceUtils.getCommandProvider(container);
if(provider == null) {
return UnexecutableCommand.INSTANCE;
// Retrieve create command from the Element Edit service
CreateElementRequest createRequest = null;
if(reference == null) {
createRequest = new CreateElementRequest(container, getElementTypeToCreate());
} else {
createRequest = new CreateElementRequest(container, getElementTypeToCreate(), reference);
ICommand createGMFCommand = provider.getEditCommand(createRequest);
Command emfCommand = new GMFtoEMFCommandWrapper(createGMFCommand);
return emfCommand;
public Object executeCommand()
Command creationcommand = null;
try
ServiceUtilsForActionHandlers util = new ServiceUtilsForActionHandlers();
creationcommand = buildCommand();
util.getTransactionalEditingDomain().getCommandStack().execute(creationcommand);
return creationcommand.getResult();
} catch (ServiceException e)
e.printStackTrace();
return null;
However it does not appear on the diagram. I have heard that I need to create the GMF part of the object and link GMF part with EMF part.
May you indicate me how I could get some examples or some help to create the graphical part of this item ?
Thanks for your help.
Re: EMF transaction for inserting a new Element in a diagram [message #1059909 is a reply to message #1048264] Wed, 22 May 2013 07:18 Go to previous messageGo to next message
} else {
return emfCommand;
try
return null;
Re: EMF transaction for inserting a new Element in a diagram [message #1075367 is a reply to message #1059909] Mon, 29 July 2013 10:05 Go to previous messageGo to next message
Leila A is currently offline Leila AFriend
Dear HERISSE Alexandre,
Thanks for your explanation!
I am trying to create an element programmatically.The code above works well with older version of Papyrus.
But the method GMFtoEMFCommandWrapper is deprecated and can't be found in the newest version.
Do you have any idea about what method I should use instead of GMFtoEMFCommandWrapper using the last version of Papyrus?
Thanks in advance! Smile
Leila
Re: EMF transaction for inserting a new Element in a diagram [message #1075441 is a reply to message #1075367] Mon, 29 July 2013 12:43 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille LetavernierFriend
The GMFtoEMFCommandWrapper was previously duplicated in a few plug-ins. You should use the one located in org.eclipse.papyrus.infra.gmfdiag.commands (org.eclipse.papyrus.commands.GMFtoEMFCommandWrapper)
Camille
Camille Letavernier
Re: EMF transaction for inserting a new Element in a diagram [message #1076418 is a reply to message #1048264] Wed, 31 July 2013 11:13 Go to previous messageGo to next message
Dear Camille,
Thank you very much, my problem is solved now.
But I have one more problem with last version I wonder if you could help me?
I need to get the editPart. Therefore, I use the two methods below. It workes well with older version but in the newest version editor.getAdapter() in method getGraphicalViewer() returns null. Can you please let me know how I should fix it?
private static EditPartViewer getGraphicalViewer()
try{
IEditorPart editor = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor();
if (editor instanceof IMultiDiagramEditor)
Object viewer = editor.getAdapter(IDiagramGraphicalViewer.class);
if (viewer instanceof EditPartViewer)
return (EditPartViewer) viewer;
catch(Exception ex){}
return null;
public static Object getEditPart(){
try{
EditPartViewer currentViewer = getGraphicalViewer();
Map<?,?> currentRegistry = currentViewer.getEditPartRegistry();
List< ? > views = DiagramEditPartsUtil.getEObjectViews(selectedelement);
for (Object view : views)
if (currentRegistry.containsKey(view))
Object part = currentRegistry.get(view);
if (part instanceof EditPart)
return part;
return null;
Thanks and regards,
Leila
Re: EMF transaction for inserting a new Element in a diagram [message #1077881 is a reply to message #1076418] Fri, 02 August 2013 09:03 Go to previous message
Hi again,
I solved the problem. If anyone has the same problem this is the solution:
EditPart editpart = (EditPart) editor.getAdapter(EditPart.class);
Leila
Previous Topic:how to create programatically an instance of given DataType in UML
Next Topic:Profile mode does not allows classes
Current Time: Tue Jan 19 13:07:07 GMT 2021
Powered by FUDForum. Page generated in 0.02074 seconds
