Home » Modeling » ATL » [ATL] EMFTVM: PackageNotFoundException: Package with uri not found
[ATL] EMFTVM: PackageNotFoundException: Package with uri not found [message #1047483] |
Tue, 23 April 2013 09:13 |
Gunnar Arndt Messages: 82 Registered: June 2012 |
Member |
I have just switched my transformation from atl2010 to emftvm, and now I get the error message
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://com.ourCustomer.dat/modeltransformation/1.0' not found. (file:/c:/otx-test/self_adjustment_of_mixture_formation.0.modeltransformation, 2, 251)
when calling a launch config, although the uri in the model file matches the one given in the Ecore metamodel, and both of them are registered in the launch config:
The header of my ATL file:
-- @atlcompiler emftvm
module transformate2otx;
create OUT: otx, time: otxDateTime, diag: otxDiagCom, data: otxDiagDataBrowsing, event:
otxEvent, flash: otxFlash, hmi: otxHmi, i18n: otxI18n, job: otxJob, log:
otxLogging, math: otxMath, measure: otxMeasure, quant: otxQuantities, string:
otxStringUtil from IN: transformate;
Do you have an idea what to do? As far as I understand what's going on, the matching between model and metamodel is done in the header anyway, so there should be no need to do that automatically by the URI.
Thank you for any suggestion!
Re: [ATL] EMFTVM: PackageNotFoundException: Package with uri not found [message #1047533 is a reply to message #1047483] |
Tue, 23 April 2013 10:48 |
> the error message
> 2, 251)
> launch config:
> string:
EMFTVM used to not automatically register EPackage namespace URIs, and stick
to the default EMF behaviour. Today's snapshot release (3.4.0.201304231212)
departs from this strategy, as it triggers errors like this, as well as
aliasing problems where multiple versions of the same metamodel linger in memory.
That said, if you have a generated metamodel, you should always load it via
the namespace URI, not from file. Only dynamic metamodels may be loaded from
their .ecore file.
Kind regards,
Dennis Wagelaar
Dennis
Re: [ATL] EMFTVM: PackageNotFoundException: Package with uri not found [message #1047889 is a reply to message #1047776] |
Tue, 23 April 2013 20:00 |
Op 23/04/13 18:24, Gunnar Arndt schreef:
> I've just done that - no change, the message comes up.
Hmm, what happens after you try this:
1. Switch to ATL perspective
2. Right-click the "ModelTransformation.ecore" file, and select "Register
Metamodel"
3. Now run the transformation again.
If this works, there is still a bug in the EMFTVM launcher...
Dennis
Dennis
Re: [ATL] EMFTVM: PackageNotFoundException: Package with uri not found [message #1048260 is a reply to message #1047483] |
Wed, 24 April 2013 08:28 |
Member |
Dennis, thanks for the hint; I had not done that yet, as I usually work in the Plug-in perspective.
The message is now gone, instead nothing happens when running the transformation.
But I get this error when compiling with yesterday's build, although output (emftvm and asm files) is created:
Cannot set EMFTVM!CodeBlock::nested to latestHandler:ATL!NavigationOrAttributeCallExp for 326c52e3:EMFTVM!CodeBlock: containment references cannot span across models
org.eclipse.m2m.atl.emftvm.util.VMException: java.lang.ClassCastException
at abstract rule BindingStat@applier#77(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl#[824:34-824:54])
Local variables: [__trace__: TRACE!TraceLink = 739274bc:TRACE!TraceLink, s: ATL!BindingStat = 42e9ac30:ATL!BindingStat, cb: EMFTVM!CodeBlock = 326c52e3:EMFTVM!CodeBlock, ln: EMFTVM!LineNumber = 7042d019:EMFTVM!LineNumber, invokeCb: EMFTVM!InvokeCb = 3256462:EMFTVM!InvokeCb, invokeCb2: EMFTVM!InvokeCb = be15f8b:EMFTVM!InvokeCb, set: EMFTVM!FieldInstruction = 7947a4c4:EMFTVM!Set]
at static EMFTVM!ExecEnv::main() : Object(platform:/plugin/org.eclipse.m2m.atl.emftvm.compiler/transformations/ATLtoEMFTVM.atl)
Local variables: []
at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.internalExecute(CodeBlockImpl.java:989)
at org.eclipse.m2m.atl.emftvm.impl.CodeBlockImpl.execute(CodeBlockImpl.java:728)
at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$WithApplierWithoutPostApplyCbState.applyFor(RuleImpl.java:1204)
at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.applyFor(RuleImpl.java:2229)
at org.eclipse.m2m.atl.emftvm.impl.RuleImpl$IsNotAbstractState.apply(RuleImpl.java:981)
at org.eclipse.m2m.atl.emftvm.impl.RuleImpl.apply(RuleImpl.java:2199)
at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.matchAllSingle(ExecEnvImpl.java:2180)
at org.eclipse.m2m.atl.emftvm.impl.ExecEnvImpl.run(ExecEnvImpl.java:2028)
at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:189)
at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:138)
at org.eclipse.m2m.atl.emftvm.compiler.AtlToEmftvmCompiler.compileWithProblemModel(AtlToEmftvmCompiler.java:107)
at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:156)
at org.eclipse.m2m.atl.engine.compiler.AtlCompiler.compile(AtlCompiler.java:125)
at org.eclipse.m2m.atl.adt.AtlBuildVisitor.visit(AtlBuildVisitor.java:115)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:126)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:95)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:52)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:124)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:108)
at org.eclipse.m2m.atl.adt.AtlBuilder.fullBuild(AtlBuilder.java:68)
at org.eclipse.m2m.atl.adt.AtlBuilder$1.run(AtlBuilder.java:49)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.m2m.atl.adt.AtlBuilder.run(AtlBuilder.java:108)
at org.eclipse.m2m.atl.adt.AtlBuilder.build(AtlBuilder.java:52)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.ClassCastException
Cannot set EMFTVM!CodeBlock::nested to latestHandler:ATL!NavigationOrAttributeCallExp for 4b5432a8:EMFTVM!CodeBlock: containment references cannot span across models
Local variables: [__trace__: TRACE!TraceLink = 2d591708:TRACE!TraceLink, s: ATL!BindingStat = 64bc7e34:ATL!BindingStat, cb: EMFTVM!CodeBlock = 4b5432a8:EMFTVM!CodeBlock, ln: EMFTVM!LineNumber = d35dd4e:EMFTVM!LineNumber, invokeCb: EMFTVM!InvokeCb = 601659f1:EMFTVM!InvokeCb, invokeCb2: EMFTVM!InvokeCb = 5b6b0e7f:EMFTVM!InvokeCb, set: EMFTVM!FieldInstruction = 5184e2bc:EMFTVM!Set]
Local variables: []
Current Time: Thu Apr 25 05:37:25 GMT 2024
Powered by FUDForum. Page generated in 0.04465 seconds
