Home » Eclipse Projects » GEF » How to share a commandstack between GEF editor and TextEditor in a multipleEditor?
How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #154667] Wed, 20 October 2004 19:12 Go to next message
I am trying to create a MultipleEditor follow the Redbook Workflow
example.
My MultipleEditor contains 2 Editor. one is GEF editor (same as example),
another is a TextEditor(also use default wizard generated).
But the problem is no matter how I changed in the TextEditor.The
MultipleEditor only recongize GEF editor actions.make the changes to Models.
How to add TextEditor action hooks into GEF commandStack?. Because
editDomain:addViewer will not accept the TextEditor.
I searched the Platform newsgroup there is no such solution.
//BOW
arfeifei
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #154691 is a reply to message #154667] Thu, 21 October 2004 03:41 Go to previous messageGo to next message
You need to track document changes and capture them as GEF commands, or
track GEF commands and turn them into document changes.
It's unfortunate that there is not a command framework in the base Eclipse.
Please vote for:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37716
"arfeifei" <arfeifei@gmail.com> wrote in message
news:cl6d19$8ke$1@eclipse.org...
> Hi
> example.
Models.
> //BOW
> arfeifei
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #155003 is a reply to message #154691] Thu, 21 October 2004 16:01 Go to previous messageGo to next message
Hi Arfeifei,
I managed to to this for my editor.
I found the simplest technique was to implement a single delegating "stack",
so to speak.
This is a 3 step approach.
1)Modify GEF command stack for the GEF editor
2)Modfify DefaultUndoManager for the Text editor
3) Write a "unified" undo manager which will delegate undo / redo operations
to either editor.
Both #1 and #2 mentioned above have their own commands and command stacks.
The basic theory behind my implementation was to add a field to each of the
commands, called a command "stamp". This can be as simple as an incremental
counter - ie. When a command is added to a stack (for the first time) -
include the current counter value. Because of the counter, you know the
command ordering.
Now for #3. It's undo and redo methods will simply check the top of both
stacks (and the command stamps) to find the appropriate command to be undone
or redone.
Instead of extensive hacking I simply modified undo methods of #1 and #2 to
point to the undo method in #3. #3 makes the correct choice as described
above and will then call the original undo method in either #1 or #2.
Well, thats the theory. For instance, you might have to consider special
cases where a single action causes commands to be executed in both stacks.
Then an undo must cascade and undo both commands. Also, the text editor
obviously does no thav e"command" in the same sense of GEF commands.
Commands may be committed only after the "next" editing operation - or
editing operations may be clubbed into a single command. So you will have to
"commit" commands more frequently - like on page changes from text to GEF
editor.
I managed to get my implementation right after several iterations of dev and
bug fixing :)
Hope this helps - let me know how it turns out,
All the best,
Brian.
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #155010 is a reply to message #155003] Thu, 21 October 2004 22:09 Go to previous messageGo to next message
Hi Brian
I will try!!!
arfeifei
"Brian Fernandes" <brian@genuitec.com> wrote in message
news:cl99hn$lhp$1@eclipse.org...
> Hi Arfeifei,
> "stack",
> so to speak.
> operations
> to either editor.
> the
> incremental
> command ordering.
> undone
> or redone.
> to
> to
> editor.
> and
> bug fixing :)
> All the best,
> Brian.
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #155041 is a reply to message #155003] Fri, 22 October 2004 03:28 Go to previous messageGo to next message
Once concern I would have is that when GEF commands redo, they typically
replay the same action on the same instance of a given model object. But,
when text commands redo, they insert new text, which might then parsed and
result in the creation of a new (but identical) structural model object.
So, if you did something like this:
1) Insert "<P>this is a paragraph</P>" into your document
2) Select the Node for <P> and change the alignment to "right".
Where 1) is a text edit, and 2) is a GEF edit.
Undo, Undo will work, but Redo, Redo will fail (silently), because the
second Redo will be changing the alignment for a stale representation for
<P>
> Hi Arfeifei,
"stack",
> so to speak.
operations
> to either editor.
the
incremental
> command ordering.
undone
> or redone.
to
to
> editor.
and
> bug fixing :)
> All the best,
> Brian.
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #155210 is a reply to message #155041] Fri, 22 October 2004 09:26 Go to previous messageGo to next message
Very valid point Randy, that slipped by me.
I don't hit this in my editor because I have a cached map of my model
objects. The text is parsed to get the "key" of a particular section of text
(which corresponds to a GEF model) and the same model is retrieved from the
cache if present.
Arfeifei, you will certainly have to look out for this; maybe you'll come up
with a better solution :)
All the best,
Brian.
Re: How to share a commandstack between GEF editor and TextEditor in a multipleEditor? [message #155380 is a reply to message #155210] Sun, 24 October 2004 22:48 Go to previous message
Originally posted by: fei.tian.istark.com
Hi Brian & Randy
Well after I tried to constrcut GEF command in text editor. finally I give
it up.I directlly using TextEditor doSave method to save the document as
XML. Every time when flipping the pages between TextEditor and GEF editor
the active editor will load the modification model from File. May be this is
not a right approch to follow the MVC model. but at least it works :(((
Hope laterlly Redbook can provide an example how integrated GEF editor and
Text editor wihtin a multipleEditor.
Thanks both of your guys! You really give me some new ideas!
Arfeifei
news:clbj6l$j9s$1@eclipse.org...
> text
> the
> cache if present.
> up
> All the best,
> Brian.
Previous Topic:Importing new classes at runtime
Next Topic:Urgent !!! re-scaling a figure
Current Time: Wed Feb 19 10:01:04 GMT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
