Home » Eclipse Projects » Remote Application Platform (RAP) » Different errors occurs in firefox and chrome when I close my custom widget
Different errors occurs in firefox and chrome when I close my custom widget [message #1044809] Fri, 19 April 2013 11:18 Go to next message
David Song is currently offline David SongFriend
Hi all,
I wrote a chart custom widget with RAP 2.0 feature, and it can be displayed in my RAP 2.0 project, but once I close the dialog or editor which the custom widget layouts in, different errors occur in different browsers. And the error code is just like below,
in Firefox:
Could not process server response:
Error: TypeError: this._clientArea is null
in Chrome:
Error: TypeError: Cannot call method 'concat' of null
Thank you very much
David
[Updated on: Fri, 19 April 2013 14:21]
Report message to a moderator
Re: Different errors occurs in firefox and chrome when I close my custom widget [message #1045447 is a reply to message #1044809] Sat, 20 April 2013 08:49 Go to previous messageGo to next message
this.parent.getClientAera()caused errors, it is ok after I get rid of it.
layout : function() {
     var area = this.parent.getClientArea();
     this.element.style.left = area[0] + "px";
     this.element.style.top = area[1] + "px";
Re: Error occurs when I close my custom widget [message #1045473 is a reply to message #1044809] Sat, 20 April 2013 09:40 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
..members.getClientArea@http://localhost:10080/rwt-resources/rap-client.js:61598
> @http://localhost:10080/rwt-resources/rap-client.js:71198
> jschart.JChart.prototype.layout@http://localhost:10080/fms:51
It seems that you try to layout your widget after it has been disposed.
I guess either you or the framework should unbind a listener. How does
the code around /fms, line 51 look like?
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Error occurs when I close my custom widget [message #1045506 is a reply to message #1045473] Sat, 20 April 2013 11:05 Go to previous messageGo to next message
Thanks Ralf for your help.
After I remove the code below, the chart widget can work well, but it give a error backgroud Invalid negative value for <rect> attribute width="-1" ,
probably the widget's rect is not set without the code below. but it works well.
the code around /fms, line 51 is the layout function
   if (!this.isRendered) {
        this.chart.setJSONData(this._chartData);
	this.chart.render(this.element.id)
   this.chart.resizeTo( area[2], area[3] );
[Updated on: Sat, 20 April 2013 11:16]
Re: Error occurs when I close my custom widget [message #1046673 is a reply to message #1045506] Mon, 22 April 2013 08:07 Go to previous messageGo to next message
The interesting part is where this layout function is bound, either to
the global rap object or to parent resize.
If it's bound to the global rap object, then it must be unbound on dispose.
Ralf
Ralf Sternberg
Re: Error occurs when I close my custom widget [message #1046720 is a reply to message #1046673] Mon, 22 April 2013 09:19 Go to previous message
I got it, thanks Ralf.
Previous Topic:chart tools for RAP
Next Topic:Status Handlers for RAP
Current Time: Sun Dec 05 06:03:27 GMT 2021
Powered by FUDForum. Page generated in 0.01468 seconds
