Home » Archived » BIRT » Dynamic SQL in BIRT
Dynamic SQL in BIRT [message #1044720] Fri, 19 April 2013 08:45 Go to next message
Dewald Gouws is currently offline Dewald GouwsFriend
Hi Guys,
I'm quite new to birt. I have to generate reports based on a SQL query.
For instance the SQL retrieves data based on a restaurant name and a set of dates.
Can I create parameters that change the query based on the selection made?
Re: Dynamic SQL in BIRT [message #1044913 is a reply to message #1044720] Fri, 19 April 2013 13:53 Go to previous messageGo to next message
Tomas Greif is currently offline Tomas GreifFriend
Member
You can use parameters http://www.eclipse.org/birt/phoenix/examples/reports/parameters/
Re: Dynamic SQL in BIRT [message #1047366 is a reply to message #1044720] Tue, 23 April 2013 05:37 Go to previous message
Noor ul Huda is currently offline Noor ul HudaFriend
You can send query using Report paramters or uisng script on beforeopen dataset event in Report.
Previous Topic:Add My own Font Path to Birt
Next Topic:Trying to create a report using BIRT API
Current Time: Mon Oct 02 09:33:14 GMT 2023
Powered by FUDForum. Page generated in 0.02679 seconds
