Home » Modeling » TMF (Xtext) » Error in extending xbase expressions
Error in extending xbase expressions [message #1043938] |
Thu, 18 April 2013 09:42 |
andrea rossi Messages: 23 Registered: April 2013 |
Hi ,
This is a part of my grammar :
grammar org.xtext.example.jade.Jade with org.eclipse.xtext.xbase.Xbase
Message returns xbase::XExpression:
SendMessage | Prova
SendMessage returns xbase::XExpression:
{SendMessage}
'send message' name = ValidID '{'
(('sender' '=' sender = STRING)? &
('content' '=' content = STRING)? &
//('language' '=' language = STRING)? &
//('ontology' '=' ontology = STRING)? &
('performative' '=' performative = Performative) &
('receivers' '{' (receivers += (MessageReceivers)+) '}' ) )
SimpleBehaviour :
'behaviour' name=ValidID 'is' typeSB = TypeSB '{'
(body=XExpressionInsideBlock ';'?)
XExpressionInsideBlock returns xbase::XExpression:
XVariableDeclaration | XExpression | Message;
Prova returns xbase::XExpression :
{Prova} 'receive message do' '{' campo = XExpressionInsideBlock '}'
I extend xbase expressions adding my expression(Message) in XExpressionInsideBlock
My expression Message is SendMessage expression or Prova expression.I extend xbase expression for use all xbase expressions and in additional my expression Messagge in SimpleBehaviour.
Then I extend AbstractModelInferrer and XbaseCompiler for translate my DSL in java.
This è my XbaseCompiler :
class JadeCompiler extends XbaseCompiler {
override protected doInternalToJavaStatement(XExpression expr,ITreeAppendable it, boolean isReferenced) {
switch expr {
SendMessage : {
newLine
append('''
ACLMessage «expr.name» = new ACLMessage(ACLMessage.«expr.performative»);
«IF expr.sender != null»
«expr.name».setSender(new AID ("«expr.sender»",AID.ISLOCALNAME));
«ENDIF»
«IF expr.content != null»
«expr.name».setContent("«expr.content»");
«ENDIF»
«FOR r : expr.receivers»
«expr.name».addReceiver(new AID ("«r.receiver»",AID.ISLOCALNAME));
«ENDFOR»
send(«expr.name»);
Prova : {
doInternalToJavaStatement(expr.campo, it, isReferenced)
append('''
ACLMessage msg = receive();
if (msg!=null){}
default :
super.doInternalToJavaStatement(expr, it, isReferenced)
override protected internalToConvertedExpression(XExpression obj, ITreeAppendable it) {
if (hasName(obj))
append(getName(obj))
else
super.internalToConvertedExpression(obj, it)
If i use SendMessage expression the translate is work but if i use Prova expression the translate don't work
Error is :
ERROR org.eclipse.xtext.builder.BuilderParticipant - Error during compilation of '..'
Re: Error in extending xbase expressions [message #1044375 is a reply to message #1044323] |
Thu, 18 April 2013 20:59 |
thank you for you replies
my grammar :
generate jade "htp://www.xtext.org/example/jade/Jade"
import 'htp://www.eclipse.org/xtext/xbase/Xbase' as xbase
Model:
'package' name = QualifiedName
elements+=AbstractElement*;
AbstractElement :
AbstractBehaviour | AgentJade
AgentJade:
'agent' name=ValidID '{'
behaviours += AddBehaviour*
messages += Message*
AddBehaviour :
'add behaviour' name=ValidID 'type' type = [AbstractBehaviour|ValidID]
SendMessage | Prova
{SendMessage}
MessageReceivers :
'receiver =' receiver = STRING
enum Performative :
REQUEST | INFORM | QUERY_IF | CFP | PROPOSE | ACCEPT_PROPOSAL | REJECT_PROPOSAL //da completare
AbstractBehaviour :
SimpleBehaviour | Behaviour
Behaviour :
'behaviour' name=ValidID 'is' typeB = 'Behaviour' '{'
(body=XExpressionInsideBlock';'?)
SimpleBehaviour :
enum TypeSB :
OneShotBehaviour | CiclicBehaviour
my compiler :
override protected doInternalToJavaStatement(XExpression expr, ITreeAppendable it, boolean isReferenced) {
switch expr {
SendMessage : {
newLine
append('''
«ENDIF»
«ENDIF»
«ENDFOR»
send(«expr.name»);
Prova : {
append('''
if (msg!=null){}
default :
if (hasName(obj))
else
my AbstractModelInferrer :
class JadeJvmModelInferrer extends AbstractModelInferrer {
@Inject extension JvmTypesBuilder
@Inject extension IQualifiedNameProvider
def dispatch void infer(Model element,
IJvmDeclaredTypeAcceptor acceptor,
boolean isPrelinkingPhase) {
for (a : element.elements) {
switch a {
AbstractBehaviour : {
switch a {
SimpleBehaviour : {
acceptor.accept(a.toClass(a.fullyQualifiedName)).initializeLater [
superTypes += a.newTypeRef('jade.core.behaviours.'+ a.typeSB.toString)
members += a.toConstructor[
documentation = '''...'''
parameters += toParameter("agent", newTypeRef(a, 'jade.core.Agent'))
body = [
append('''
super(agent);
members += a.toMethod("action",a.newTypeRef(Void::TYPE))[
body = a.body
AgentJade : {
documentation = a.documentation
superTypes += a.newTypeRef('jade.core.Agent')
members += a.toMethod("setup",a.newTypeRef(Void::TYPE))[
body = [append('''
«FOR b : a.behaviours»
«b.type.name» «b.name» = new «b.type.name»(this);
addBehaviour(«b.name»);
«ENDFOR»
for (m : a.messages) {
switch m {
SendMessage : {
append('''
ACLMessage «m.name» = new ACLMessage(ACLMessage.«m.performative»);
«IF m.sender != null»
«m.name».setSender(new AID ("«m.sender»",AID.ISLOCALNAME));
«ENDIF»
«IF m.content != null»
«m.name».setContent("«m.content»");
«ENDIF»
«FOR r : m.receivers»
«m.name».addReceiver(new AID ("«r.receiver»",AID.ISLOCALNAME));
«ENDFOR»
send(«m.name»);
}//sendMe
}//switch
}//for
]//body
}//agent jade
}//switch
}//for
}//infer
}//class
my RuntimeModule :
public class JadeRuntimeModule extends org.xtext.example.jade.AbstractJadeRuntimeModule {
public Class<? extends XbaseCompiler> bindXbaseCompiler() {
return JadeCompiler.class;
public Class<? extends ITypeComputer> bindITypeComputer() {
return JadeTypeComputer.class;
my TypeComputer :
class JadeTypeComputer extends XbaseTypeComputer {
override computeTypes(XExpression expression, ITypeComputationState state) {
if(expression instanceof SendMessage) {
_computeTypes(expression as SendMessage, state);
} else if (expression instanceof Prova){
_computeTypes(expression as Prova,state)}
else {
super.computeTypes(expression, state)
protected def _computeTypes(SendMessage expression, ITypeComputationState state) {
//super._computeTypes(expression as XExpression, state)
state.acceptActualType(getTypeForName(typeof(Void), state))
protected def _computeTypes(Prova expression, ITypeComputationState state) {
//super.computeTypes(expression.campo, state)
Error :
at org.eclipse.xtext.xbase.compiler.TypeReferenceSerializer.serialize(TypeReferenceSerializer.java:90)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:342)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:338)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.serialize(AbstractXbaseCompiler.java:334)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.appendVariableTypeAndName(XbaseCompiler.java:663)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler._toJavaStatement(XbaseCompiler.java:643)
at org.eclipse.xtext.xbase.compiler.XbaseCompiler.doInternalToJavaStatement(XbaseCompiler.java:441)
at org.xtext.example.jade.jvmmodel.JadeCompiler.doInternalToJavaStatement(JadeCompiler.java:93)
at org.xtext.example.jade.jvmmodel.JadeCompiler.doInternalToJavaStatement(JadeCompiler.java:83)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.internalToJavaStatement(AbstractXbaseCompiler.java:297)
at org.eclipse.xtext.xbase.compiler.AbstractXbaseCompiler.compile(AbstractXbaseCompiler.java:236)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateExecutableBody(JvmModelGenerator.java:1111)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateMember(JvmModelGenerator.java:809)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateMember(JvmModelGenerator.java:1777)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:286)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator$2.apply(JvmModelGenerator.java:1)
at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
at org.eclipse.xtext.xbase.compiler.LoopExtensions$1.apply(LoopExtensions.java:39)
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
at org.eclipse.xtext.xbase.compiler.LoopExtensions.forEach(LoopExtensions.java:42)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._generateBody(JvmModelGenerator.java:290)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateBody(JvmModelGenerator.java:1751)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.generateType(JvmModelGenerator.java:209)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator._internalDoGenerate(JvmModelGenerator.java:200)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.internalDoGenerate(JvmModelGenerator.java:1734)
at org.eclipse.xtext.xbase.compiler.JvmModelGenerator.doGenerate(JvmModelGenerator.java:181)
at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:291)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:221)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:170)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:146)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Re: Error in extending xbase expressions [message #1044812 is a reply to message #1044375] |
Fri, 19 April 2013 11:16 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Andrea,
your type computer looks bogus to me. According to the JavaDoc of
ITypeComputer, you are responsible to trigger the type computation for
all child expressions of your specialized cases. This is important since
you usually want to specialize the expected type for your contained
expressions.
Currently you don't do that for 'Prova'. You have to use something like
state.withExpection(..).computeTypes(prova.campo).
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 18.04.13 22:59, schrieb andrea rossi:
> my grammar :
> Model:
> 'package' name = QualifiedName elements+=AbstractElement*;
> AbstractElement :
> AgentJade:
> 'agent' name=ValidID '{' behaviours += AddBehaviour*
> AddBehaviour : 'add behaviour' name=ValidID 'type' type =
> Message returns xbase::XExpression: SendMessage | Prova
> SendMessage returns xbase::XExpression: {SendMessage}
> MessageReceivers : 'receiver =' receiver = STRING ;
> enum Performative :
> AbstractBehaviour : SimpleBehaviour | Behaviour
> Behaviour : 'behaviour' name=ValidID 'is' typeB = 'Behaviour' '{'
> SimpleBehaviour : 'behaviour' name=ValidID 'is' typeSB = TypeSB '{'
> enum TypeSB : OneShotBehaviour | CiclicBehaviour ;
> Prova returns xbase::XExpression : {Prova} 'receive message do' '{'
> my compiler :
> switch expr {
> SendMessage : {
> newLine
> append('''
> «ENDIF»
> «ENDIF»
> «ENDFOR»
> send(«expr.name»);
> Prova : {
> append('''
> if (msg!=null){}
> default :
> if (hasName(obj))
> else super.internalToConvertedExpression(obj, it)
> IJvmDeclaredTypeAcceptor acceptor, boolean
> switch a {
> switch a {
> SimpleBehaviour : {
> superTypes +=
> body = [
> append('''
> super(agent);
> members +=
> body = a.body
> AgentJade : {
> members +=
> body = [append('''
> «ENDFOR»
> switch m {
> SendMessage : {
> append('''
> «ENDIF»
> «ENDIF»
> «ENDFOR»
> send(«m.name»);
> }//sendMe
> }//switch
> }//for
> ]//body
> }//agent jade
> }//switch
> }//for
> }//infer
> }//class
> my RuntimeModule :
> @Override
> my TypeComputer :
> state) {
> else {
> state) {
> Error :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
Current Time: Tue Apr 23 09:30:11 GMT 2024
Powered by FUDForum. Page generated in 0.03581 seconds
