Odd Behavior in Example RCP Projects [message #1042870] |
Tue, 16 April 2013 21:24 |
Hi, I am just starting out with RCP and am running into some odd behavior in the provided Plug-in Project Templates, particularly "RCP Mail Template" and "RCP Application with a view". The problems arise when these templates are unmodified.
First, when I run the RCP Mail project from "Launch an Eclipse application" and then add a few tabs to the folder view (via the plus button on the coolbar), then exit the program, then reopen it, everything is exactly the way it was when I exited the program. If I opened 5 tabs the last time I ran the program, there would be 5 open tabs the next time I run, regardless of the initial configuration set by the perspective. This holds true even if I restart Eclipse entirely.
Second, after starting and stopping the project a few times and manipulating the UI by adding and removing tabs in the folder, strange things start to happen. When I close a tab, sometimes two tabs close, or a new one will open. When I click on tabs, they will rearrange themselves. If I move a tab's order, my screen flickers (which is the scariest).
Occasionally I will get a Java error and stack trace. I have included an example at the bottom of this post.
These sound like memory management problems, which surprises me since I never run into those sort of problems in Java. Maybe the latest Java has a flaw? I am running on Windows 7.
Eclipse Info:
Eclipse for RCP and RAP Developers
Version: Juno Service Release 2
Build id: 20130225-0426
I also have one plugin installed: Window Builder Pro
I am quite perplexed and hope someone can tell me what I'm doing wrong. I have tried to create the project specifying older versions of Java and altering the settings with no luck. Again, these problems arise without any modification to the template. I just run the project I create from template.
Thank you in advance for your help!
!SESSION 2013-04-16 21:14:06.578 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_06
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product mailtest2.product
Command-line arguments: -product mailtest2.product -data G:\sandbox\analysis\workspace/../runtime-mailtest2.product -dev file:G:/sandbox/analysis/workspace/.metadata/.plugins/org.eclipse.pde.core/mailtest2.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 2 0 2013-04-16 21:14:12.100
!MESSAGE Blocked recursive attempt to activate part
!STACK 0
java.lang.IllegalStateException
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:119)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1038)
at org.eclipse.swt.widgets.Control.fixFocus(Control.java:1053)
at org.eclipse.swt.widgets.Control.setVisible(Control.java:3762)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.clearTR(StackRenderer.java:650)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.adjustTR(StackRenderer.java:655)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1126)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:422)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:389)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:606)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:579)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:549)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2836)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2417)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:5152)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4598)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2570)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:1098)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:3303)
at mailtest2.View.setFocus(View.java:81)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:189)
at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:231)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:237)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:208)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:106)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:101)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.mouseUp(StackRenderer.java:942)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1053)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at mailtest2.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.02582 seconds
