GridLayout Problems after Juno SP2 Update [message #1041906] |
Mon, 15 April 2013 18:46 |
Thomas Kernstock Messages: 29 Registered: July 2009 Location: Vienna |
Hi @all,
I'm using SWT Designer Version: 1.5.2 Build id: 2013.03.07 (Build from January has the same problem!) and different Juno installations.
To make short what took me some hours ->
I use a workspace with Juno Java EE IDE 1.5.1.20121004-1506 and the above version of WindowsBuilder. I open my workspace and a JFace Application window with the designer - it shows up like in BeforeJunoSP2.jpg.
I copied the complete juno installation and updated to 1.5.2.20130211-1820. No other plugin is updated! When I open the same Workspace and java class like before, it shows up like in AftfterJunoSP2.jpg.
Of course I also tried starting the updated juno with -clean, but that didn't help.
When I run my program the layout is correct !
Any ideas ? Is this a bug or do I need to update/delete .. something else ?
Thanx
Thomas
[Updated on: Mon, 15 April 2013 18:49] Report message to a moderator
Re: GridLayout Problems after Juno SP2 Update [message #1043810 is a reply to message #1043633] |
Thu, 18 April 2013 06:41 |
I'm using Windows 7 64-bit.
If it was just an eclipse glitch I wonder why the layout is fine when I start my application (directly in eclipse). Too bad you can't reproduce the problem but as you can see in here I'm not the only one.
What I also found in the forum was that the problems seems to go away using eclipse 4.2.2 with the old version of WB (5.1.0). I cannot confirm this - I tried 5.1.0 too but the problem persists.
[Updated on: Thu, 18 April 2013 07:00] Report message to a moderator
FUDForum. Page generated in 0.04206 seconds
