Home » Eclipse Projects » EclipseLink » eclipselink.id-validation=NONE not working
eclipselink.id-validation=NONE not working [message #1041840] Mon, 15 April 2013 16:46 Go to next message
Jay Roberts is currently offline Jay RobertsFriend
I'm setting up with Eclipselink NoSql using mongo.
I do a persist with eclipselink.id-validation="NONE", but I still get the following error as below when persisting in a junit test. The persistence.xml and class are shown below. I annotated the class with @PrimaryKey for good measure, but any combination of this and the eclipselink.id-validation="NONE" results in the same result. Any help would be appreciated..
Jay
<persistence xmlns="<not enough forum messages for links>" xmlns:xsi="<not enough forum messages for links>" xsi:schemaLocation="<not enough forum messages for links>" version="2.0">
<persistence-unit name="test" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<exclude-unlisted-classes>false</exclude-unlisted-classes>
<properties>
<property name="eclipselink.target-database" value="org.eclipse.persistence.nosql.adapters.mongo.MongoPlatform"/>
<property name="eclipselink.nosql.connection-spec" value="org.eclipse.persistence.nosql.adapters.mongo.MongoConnectionSpec"/>
<property name="eclipselink.nosql.property.mongo.port" value="27017"/>
<property name="eclipselink.nosql.property.mongo.host" value="localhost"/>
<property name="eclipselink.nosql.property.mongo.db" value="prod"/>
<property name="eclipselink.id-validation" value="NONE"/>
</properties>
</persistence-unit>
</persistence>
@Entity(name="test_eclipselink_organizations")
@NoSql(dataFormat=DataFormatType.MAPPED)
@PrimaryKey(validation=IdValidation.NONE)
public class Organization implements Serializable {
private static final long serialVersionUID = 4052830407245941276L;
@Id
@Column(name="_id")
private String _id;
javax.persistence.RollbackException: Exception [EclipseLink-7197] (Eclipse Persistence Services - 2.4.1.v20121003-ad44345): org.eclipse.persistence.exceptions.ValidationException
Exception Description: Null or zero primary key encountered in unit of work clone [com.sheerid.model.Organization@11ae9aaa], primary key [null]. Set descriptors IdValidation or the "eclipselink.id-validation" property.
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:102)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:63)
at com.sheerid.service.organization.jpa.JPAOrganizationDAOTest.testBasicIO(JPAOrganizationDAOTest.java:23)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:236)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:134)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:113)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray(ReflectionUtils.java:189)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:165)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:85)
at org.apache.maven.surefire.booter.ForkedBooter.runSuitesInProcess(ForkedBooter.java:103)
at org.apache.maven.surefire.booter.ForkedBooter.main(ForkedBooter.java:74)
Caused by: Exception [EclipseLink-7197] (Eclipse Persistence Services - 2.4.1.v20121003-ad44345): org.eclipse.persistence.exceptions.ValidationException
at org.eclipse.persistence.exceptions.ValidationException.nullPrimaryKeyInUnitOfWorkClone(ValidationException.java:1451)
at org.eclipse.persistence.descriptors.changetracking.DeferredChangeDetectionPolicy.calculateChanges(DeferredChangeDetectionPolicy.java:108)
at org.eclipse.persistence.descriptors.changetracking.DeferredChangeDetectionPolicy.calculateChangesForExistingObject(DeferredChangeDetectionPolicy.java:55)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.calculateChanges(UnitOfWorkImpl.java:647)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1494)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:266)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1147)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84)
... 30 more
Re: eclipselink.id-validation=NONE not working [message #1042468 is a reply to message #1041840] Tue, 16 April 2013 13:22 Go to previous message
James Sutherland is currently offline James SutherlandFriend
Having a null Id is not valid. What are you trying to do? If you want to use a generated Id use the @GeneratedValue annotation and a Mongo OID will be generated.
James : Wiki : Book : Blog : Twitter
Previous Topic:org.eclipse.persistence.eis.adapters package Missing in 2.4.0
Next Topic:Using Left Join without metamodel classes
Current Time: Thu Aug 22 16:44:32 GMT 2019
Powered by FUDForum. Page generated in 0.02267 seconds
