Home » Eclipse Projects » EGit / JGit » Re-indexing even though "Refresh when index changes" is off
Re-indexing even though "Refresh when index changes" is off [message #1041097] Sun, 14 April 2013 16:14 Go to next message
Philip Aston is currently offline Philip AstonFriend
egit 2.3.1 keeps re-indexing a git repository. It burns a lot of CPU, and never completes.
Re-indexing seems to be triggered on every save (even to files on completely different files systems).
- I've unchecked "Refresh resources when index changes"
- I have no open projects that use that repository.
I believe egit is mistakenly identifying projects in .gitignored subdirectories as belonging to the parent repository.
How do I stop it?
- Phil
Re: Re-indexing even though "Refresh when index changes" is off [message #1042709 is a reply to message #1041097] Tue, 16 April 2013 19:32 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
Philip Aston skrev 2013-04-15 17.35:
Sounds likely. Can you report this to bugs.eclipse.org (I did not check if this is reported), but I know
there is something relating to not completely ignoring .ignored folders (it scans and /then/ ignores).
> How do I stop it?
The nightly builds might be better (faster), causing less problem if you have many repositories, but the
basic issue is mostly likely still there.
-- robin
Re: Re-indexing even though "Refresh when index changes" is off [message #1042792 is a reply to message #1042709] Tue, 16 April 2013 22:14 Go to previous message
Thanks Robin. I've opened Bug 405833.
Fortunately (for me), the problem has gone away. I think this is because I de-selected "Auto share projects located in a git repository", but I can't be sure. I'll continue to try to trigger the problem, and report any "success" against 405833.
Previous Topic:push readme.
Next Topic:grep with jgit
Current Time: Thu Sep 16 16:44:52 GMT 2021
Powered by FUDForum. Page generated in 0.02251 seconds
