*SOLVED* Yellow confirmation box on ALL shortcuts [message #1040432] |
Sat, 13 April 2013 15:23 |
Max . Messages: 2 Registered: April 2013 |
in all kind of view (editors, search fields etc.) pressed binded shortcuts executs it and opens a yellow box inside the eclipse main frame at bottom right corner containing a description an the shortcut.
Result: the yellow box gets the focus and all following keys except ESC and ENTER (executes the command another time) are lost.
How do I disable this "feature"?
Thanks!
using:
Eclipse IDE for Java Developers
Version: Juno Service Release 2
Build id: 20130225-0426
[Updated on: Tue, 16 April 2013 10:18] Report message to a moderator
Re: SOLVED [message #1053675 is a reply to message #1042356] |
Tue, 07 May 2013 08:31 |
Claudio Heeg Messages: 75 Registered: April 2013 |
Member |
Same thing happened to me just now, same build as OP.
Deleting the .metadata folder helps once, after the second restart the problem reappears. Gotta be a plugin problem.
Edit:
The culprit here was
E4 CSS Spy (Incubation) 0.12.0.v20111206-1509-17B-7w3122231703257.
Installing
E4 CSS Spy (Incubation) 0.12.0.v20111206-1509-17B-7w3123161302752
on the other hand works fine.
[Updated on: Tue, 07 May 2013 09:58] Report message to a moderator
FUDForum. Page generated in 0.05283 seconds
