CDO Server not running [message #1040279] |
Sat, 13 April 2013 09:46 |
Lakhveer Singh Messages: 26 Registered: March 2013 |
hello friends,
i m working on eclipse application in which i m using CDO and EMF framework.
now i m stucked in running CDO Server.
i m using PostgreSQL as my database and trying to run CDO server for that, but its not working can any body help me here.
i get the following error while running the cdo server
[ERROR] org.postgresql.util.PSQLException: Protocol error. Session setup failed.
org.eclipse.net4j.db.DBException: org.postgresql.util.PSQLException: Protocol error. Session setup failed.
the following is the code of mine cdo-server.xml
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036" />
<repository name="demo">
<store type="db">
<mappingStrategy type="horizontal" />
<dbAdapter name="postgresql" />
<dataSource class="org.postgresql.ds.PGSimpleDataSource"
url="jdbc:postgresql://localhost:5433/postgres" databaseName="postgres"
user="postgres" password="admin" />
</store>
</repository>
</cdoServer>
please tell me, if i have went wrong any where!
[Updated on: Sat, 13 April 2013 09:53] Report message to a moderator
Re: CDO Server not running [message #1041509 is a reply to message #1040279] |
Mon, 15 April 2013 07:27 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
On 13-04-13 11:46, Lakhveer Singh wrote:
> hello friends,
> framework.
I don't think many people will be inclined to respond to your question,
without a more elaborate description of what "stuck" means... I would
recommend, a problem description, steps taken, stack-traces, version
numbers etc.. You know the regular technical stuff one needs to actually
help out.
> <cdoServer>
> <store type="db">
> </store>
> </repository>
> </cdoServer>
Re: CDO Server not running [message #1041613 is a reply to message #1040279] |
Mon, 15 April 2013 10:17 |
Am 13.04.2013 11:46, schrieb Lakhveer Singh:
> hello friends,
I agree with Christophe, "is not working" is not a problem description that invites others to help you.
> <cdoServer>
> <store type="db">
I'm not a PostgreSQL expert but you could try this:
<dbAdapter name="postgresql"/>
serverName="localhost"
portNumber="5432"
user="postgres"
password="admin"/>
Cheers
/Eike
http://www.esc-net.de
> </store>
> </repository>
> </cdoServer>
Cheers
/Eike
Re: CDO Server not running [message #1058547 is a reply to message #1041613] |
Tue, 14 May 2013 12:40 |
thanks for replying,
sorry for replying late, i was working on other module for a time,
i made changes in cdo-server.xml as you said and it was running succesfully,
but when i run the cdo server second time it gives and exception
!MESSAGE org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
!STACK 0
org.eclipse.net4j.db.DBException: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getMaxID(ObjectTypeTable.java:185)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTypeMapper.getMaxID(DelegatingObjectTypeMapper.java:85)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.repairAfterCrash(AbstractHorizontalMappingStrategy.java:94)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.repairAfterCrash(HorizontalMappingStrategy.java:204)
at org.eclipse.emf.cdo.server.internal.db.DBStore.repairAfterCrash(DBStore.java:679)
at org.eclipse.emf.cdo.server.internal.db.DBStore.reStart(DBStore.java:661)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:556)
at org.eclipse.net4j.util.lifecycle.Lifecycle.internalActivate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:162)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1846)
at org.eclipse.net4j.util.lifecycle.ShareableLifecycle.internalActivate(ShareableLifecycle.java:43)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:208)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
Caused by: org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2102)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1835)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:500)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:374)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:254)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getMaxID(ObjectTypeTable.java:174)
... 23 more
!ENTRY org.eclipse.equinox.app 4 0 2013-05-14 17:39:53.791
!STACK 0
... 23 more
[ERROR] org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
... 23 more
can u help me here..!
FUDForum. Page generated in 0.03362 seconds
