Home » Modeling » TMF (Xtext) » Different generated file directory organization for plugin project and for normal java project?(xtext code generation)
Different generated file directory organization for plugin project and for normal java project? [message #1039515] Fri, 12 April 2013 08:50
Hao Zhang is currently offline Hao ZhangFriend
I am following the "domain-model" example, I create two projects in the run-time eclipse. One is a normal java project "sad", the other one is a plug-in project "PluginToTestDomainmodel". Then I create a .dmodel file for each of them. But I have a different file directory organization in the src_gen file directory. The image of the file direcory organization can be seen in the attached file.
index.php/fa/14351/0/
  • Attachment: Untitled.png
    (Size: 28.61KB, Downloaded 106 times)
[Updated on: Fri, 12 April 2013 08:52]
Report message to a moderator
Previous Topic:Highlight After Auto-Correct
Next Topic:Is it possible to define and use "enum" in the ".dmodel" file?
Current Time: Tue Feb 25 00:07:10 GMT 2020
Powered by FUDForum. Page generated in 0.03562 seconds
