Home » Language IDEs » ServerTools (WTP) » [WTP 1.0RC5] Deploy on Tomcat 5.5
[WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152821] Mon, 19 December 2005 10:53 Go to next message
i'm trying to deploy a dynamic web application on Tomcat 5.5 and i'm unable
to deploy application to server.
For clean testing i created a new empty web application and results are same
as with my own webapp :
1) Right click on project > Run As > Run on Server = No launchable artifact
could be found in the selection.
2) Servers view > right click on server > Add and Remove projects = There
are no projects that can be added or removed from the server.
Now i want to know, how to deploy webapp to Tomcat 5.5 ?
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152879 is a reply to message #152821] Mon, 19 December 2005 14:59 Go to previous messageGo to next message
I've had this problem a few times, mostly w/ RC4. I've found that just
deleting the tomcat server and re-creating it + adding the project to it
solved the problem. I'm sure there's an easier way or even a good
explanation but this seemed to solve it for me.
Since upgrading to RC5 I haven't had this problem (yet).
HTH
-v
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152888 is a reply to message #152879] Mon, 19 December 2005 15:04 Go to previous messageGo to next message
Problem is still there. Deleted server from Servers view, from Server >
Installed runtimes and completly deleted all files/directories
from .metadata/.plugins/org.eclipse.wst.server.core. After that i recreated
the new server via Servers view. Still no way to add Dynamic Web Project to
this server.
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152896 is a reply to message #152888] Mon, 19 December 2005 15:09 Go to previous messageGo to next message
What version of Tomcat are you using? I'm using 5.5.12 and it is working
flawlessly for me (since deleting, re-creating, and updating to RC5.)
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152919 is a reply to message #152896] Mon, 19 December 2005 15:56 Go to previous messageGo to next message
Eclipse 3.1.1
Sun JDK 1.5.0_06
Apache Tomcat 5.5.12
Gentoo Linux
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152927 is a reply to message #152919] Mon, 19 December 2005 16:12 Go to previous messageGo to next message
I too am a Gentoo user and had the exact same problem. However, removing
Tomcat and re-configuring it and re-adding the project to it completely
got rid of this problem for me.
If it were me, I'd probably try creating a new web project and adding the
files from your existing project to it. However, this may not be the best
way to go. All I can tell you is that I'm no longer having this problem
on Linux or Windows.
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152934 is a reply to message #152927] Mon, 19 December 2005 16:48 Go to previous messageGo to next message
If you reread my first post this was first thing i tried. Now i tried it
again after deleting server and result is still same - no possibility to
deploy it via WTP.
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152950 is a reply to message #152934] Mon, 19 December 2005 18:45 Go to previous messageGo to next message
> deploy it via WTP.
> František Augusztin
If you're having issues with the Tomcat within Gentoo, I'd recommend
just grabbing a binary copy from apache's site and just unzipping it to
a directory instead of using emerge. We're currently trying to rework a
lot of the J2EE stuff in Gentoo.
Sorry for the hassle. This maybe a Gentoo issue :/
~ Chris
zx@gentoo.org
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152958 is a reply to message #152950] Mon, 19 December 2005 22:25 Go to previous messageGo to next message
Originally posted by: spam.scientifik.com
Ah ha! Maybe that's the difference! I always download a binary from
apache...I never emerge tomcat (or any of my java stuff for that matter.)
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152966 is a reply to message #152888] Mon, 19 December 2005 22:36 Go to previous messageGo to next message
On Mon, 19 Dec 2005 15:04:37 -0500, Franti=C5=A1ek Augusztin <frantisek@=
> Problem is still there. Deleted server from Servers view, from Server =
> from .metadata/.plugins/org.eclipse.wst.server.core. After that i recr=
eated
> the new server via Servers view. Still no way to add Dynamic Web Proje=
ct to
> this server.
Hopefully you've got this solved, but, if not, there is one part of this=
"delete and re-define"
procedure you didn't mention explicitly ... the times I've had to do thi=
s, I found it helpful,
after deleting from preferences (server runtimes), the Servers Project, =
and the servers view ...
I shutdown and restarted eclipse. That shutdown and restart seemed requi=
red to really get rid of it.
Then, once that done,
I could redefine and use just fine. I'll admit, though, I haven't had th=
is problem for a while,
so if you ever find what it is, or have a reproducable scenerio, please =
open a bug.
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152980 is a reply to message #152950] Tue, 20 December 2005 02:45 Go to previous messageGo to next message
I was never unable to use WTP with Tomcat installed via Gentoo (by the way,
there is no Tomcat 5.5.12 in portage ;-). I always used the binary copy
from apache.
I will try the delete, restart eclipse, recreate procedure ASAP.
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152988 is a reply to message #152966] Tue, 20 December 2005 04:09 Go to previous messageGo to next message
> "delete and re-define" procedure you didn't mention explicitly ... the
> times I've had to do this, I found it helpful, after deleting from
> preferences (server runtimes), the Servers Project, and the servers view
> ... I shutdown and restarted eclipse. That shutdown and restart seemed
> required to really get rid of it. Then, once that done, I could redefine
> and use just fine. I'll admit, though, I haven't had this problem for a
> while, so if you ever find what it is, or have a reproducable scenerio,
> please open a bug.
Still doesn't work. What i see :
1) when i open the project, it jumps to "Dynamic Web Projects" in Project Explorer.
2) in Project properties:
a) Server :
This project cannot be deployed to a server.
b) Project Facets :
Dynamic Web Module 2.4
Java 5.0 (tried 1.4 too, no change)
c) Java build path :
I. my own libraries
II. JRE System Library [sun-jdk-1.5.0.06] - lists JDK JAR-s
III. Tomcat v5.5 runtime - lists basic JAR-s from Tomcat
IV. Web App Libraries [cedep] - this contains only the "Access rules" entry
3) in Servers view there is a Tomcat v5.5 Server@localhost, but no Dynamic Web Project can be added.
I will try later with a clean Eclipse instance, maybe conflict with some plugin.
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #152996 is a reply to message #152988] Tue, 20 December 2005 04:48 Go to previous messageGo to next message
> plugin.
Ok, it looks like complete cleanup of features/plugins (now only EMF, GEF,
XSD and WTP are present) it can finally deploy apps to Tomcat 5.5. Thanks
to all for helping me, this is soo weird issue.
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #153082 is a reply to message #152958] Wed, 21 December 2005 04:57 Go to previous messageGo to next message
Re Gentoo: https://bugs.eclipse.org/bugs/show_bug.cgi?id=113484
Maybe until this feature is implemented you will always have to use a
standard apache binary distribution of tomcat.
Darryl
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #153214 is a reply to message #152996] Wed, 21 December 2005 10:55 Go to previous messageGo to next message
I had once this problem and after some tests, I found out it was because I was trying to use a JDK 1.4 with Tomcat 5.5. I had no error messages or anything, my project was just no there. But it appeared as soon as I changed to JDK 1.5. Maybe you are having the same issue.
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #153324 is a reply to message #153214] Thu, 22 December 2005 10:46 Go to previous messageGo to next message
Nope. I allways use JDK 1.5 (as stated in my another post, i use Sun JDK
1.5.0_06).
František Augusztin
Re: [WTP 1.0RC5] Deploy on Tomcat 5.5 [message #154847 is a reply to message #152980] Thu, 05 January 2006 01:51 Go to previous message
Originally posted by: pfgrobler.gmail.com
In my case using tomcat 5.0
\.metadata\.plugins\org.eclipse.wst.server.core\modules.xml still had a
refereance to my web project.
<modules>
<module moduleId="org.eclipse.jst.j2ee.server:TestWebProject"
serverId="1_5_06_8_47_AM1"/>
</modules>
Deleteing the referance resolved the problem for me.
Previous Topic:WTP RC5 "parsing wsdl" slow/hangs
Next Topic:installing WTP 1.0 from Eclipse update manager
Current Time: Thu Apr 17 18:36:20 EDT 2025
Powered by FUDForum. Page generated in 0.05384 seconds
