Home » Modeling » TMF (Xtext) » Use Tab and Enter for Scobe
Use Tab and Enter for Scobe [message #1036476] Mon, 08 April 2013 12:40 Go to next message
junior developer is currently offline junior developerFriend
Hi all ,
Is it possible install meaning to tab and enter? Let's say i push enter button and begin scoping of a component then i write that components property with tab(indent). When i push enter,scoping of that component should finish so may i use enter instead of curly brackets.i want write a grammar without curly brackets.
For Example:Defined A in the language, b is defined under the A (A'scoping is fineshed when B's scoping is stared)
Element A //started A's scoping
b //b is in the A's scoping
Element B //star B's scoping and A's scoping is finished
c
Best regards;
Re: Use Tab and Enter for Scobe [message #1036497 is a reply to message #1036476] Mon, 08 April 2013 13:05 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
if I understand your question correctly
Model: elements+=Element*;
Element: 'Element' name=ID
  children+=Child*
Child: name=ID;
should do what you are looking for in the easy case. Curly brackets are not necessary for "nesting", they only make it much easier in many cases.
If tabulators are significant in your language, it becomes a bit more complicated as white spaces is something Xtext does not care about by default. However, there are examples for languages where indentation plays a role (e.g. http://www.eclipse.org/forums/index.php/mv/msg/174823/556885/)
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: Use Tab and Enter for Scobe [message #1037046 is a reply to message #1036497] Tue, 09 April 2013 05:48 Go to previous message
Hi Alexander,
Yes I wanted to learn exact to it .Example have been very helpful for me but source code is not found githup.com. Thank you very much
Best regards
[Updated on: Tue, 09 April 2013 07:21]
Report message to a moderator
Previous Topic:Why there is an additional .smap file when code are automatically generated?
Next Topic:Path expressions with dot and imports/packages
Current Time: Tue Apr 16 23:01:58 GMT 2024
Powered by FUDForum. Page generated in 2.67623 seconds
