Help in analysis [message #1035069] |
Sat, 06 April 2013 09:10 |
ss ss Messages: 7 Registered: April 2013 |
Dear All,
I am new to this Memory Analyser tool. I am running a socket based application run the a database pooling and will various select and insert statements in it. Below is my results from the leak hunter.Suspect 2 I guess is due to nature I am pooling so the connection are alive all the time. I cant intepret well the suspect 1 as when I press the details it give a long list of following details.
java.lang.ref.Finalizer @ 0xf5e19670 40 92,688
next java.lang.ref.Finalizer @ 0xf5e1a6a8 40 93,024
next java.lang.ref.Finalizer @ 0xf5e1bda0 40 122,768
Suspect 1.
The class "java.lang.ref.Finalizer", loaded by "<system class loader>", occupies 1,337,176 (30.93%) bytes. The memory is accumulated in one instance of "java.lang.ref.Finalizer" loaded by "<system class loader>".
Keywords
Suspect 2
6 instances of "com.mysql.jdbc.JDBC4Connection", loaded by "sun.misc.Launcher$ExtClassLoader @ 0xf58bf000" occupy 432,624 (10.01%) bytes.
Biggest instances:
•com.mysql.jdbc.JDBC4Connection @ 0xf61c54f8 - 94,864 (2.19%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf61c4678 - 86,600 (2.00%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf61c4bf8 - 85,456 (1.98%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf626c348 - 68,000 (1.57%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf626c7d0 - 68,000 (1.57%) bytes.
Keywords
FUDForum. Page generated in 0.01940 seconds
