Home » Language IDEs » ServerTools (WTP) » Tutorial Broken?
Tutorial Broken? [message #151631] Tue, 13 December 2005 10:16 Go to next message
Originally posted by: leftout.nowhere.com
Hello, When I follow the tutorial as exactly as possible for creating a
simple ejb, when I go to deploy the ZooProject ear, when I start the JBoss
Server, I get the following error (Windows XP, JDK1.4.2_09, JBoss 3.2.3):
09:10:05,748 ERROR [MainDeployer] Could not initialise deloyment:
file:/D:/jboss-3.2.3/server/default/deploy/ZooBeansProjectEA R.ear
org.jboss.deployment.DeploymentException: Failed to find module file:
ZooBeansProject.jar
at org.jboss.deployment.EARDeployer.init(EARDeployer.java:171)
at org.jboss.deployment.MainDeployer.init(MainDeployer.java:696 )
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:6 32)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:6 05)
at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source)
at
at java.lang.reflect.Method.invoke(Method.java:324)
at
org.jboss.mx.capability.ReflectedMBeanDispatcher.invoke(Refl ectedMBeanDispatcher.java:284)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.j ava:546)
at org.jboss.mx.util.MBeanProxyExt.invoke(MBeanProxyExt.java:17 7)
at $Proxy6.deploy(Unknown Source)
at
org.jboss.deployment.scanner.URLDeploymentScanner.deploy(URL DeploymentScanner.java:302)
at
org.jboss.deployment.scanner.URLDeploymentScanner.scan(URLDe ploymentScanner.java:476)
at
org.jboss.deployment.scanner.AbstractDeploymentScanner$Scann erThread.doScan(AbstractDeploymentScanner.java:201)
at
org.jboss.deployment.scanner.AbstractDeploymentScanner.start Service(AbstractDeploymentScanner.java:274)
at
org.jboss.system.ServiceMBeanSupport.start(ServiceMBeanSuppo rt.java:192)
at sun.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
at
at
at
org.jboss.system.ServiceController$ServiceProxy.invoke(Servi ceController.java:976)
at $Proxy0.start(Unknown Source)
at org.jboss.system.ServiceController.start(ServiceController.j ava:394)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at
at
at $Proxy4.start(Unknown Source)
at org.jboss.deployment.SARDeployer.start(SARDeployer.java:226)
at org.jboss.deployment.MainDeployer.start(MainDeployer.java:83 2)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:6 42)
at org.jboss.deployment.MainDeployer.deploy(MainDeployer.java:5 89)
at
at
at
at $Proxy5.deploy(Unknown Source)
at org.jboss.system.server.ServerImpl.doStart(ServerImpl.java:3 84)
at org.jboss.system.server.ServerImpl.start(ServerImpl.java:291 )
at org.jboss.Main.boot(Main.java:150)
at org.jboss.Main$1.run(Main.java:395)
at java.lang.Thread.run(Thread.java:534)
Re: Tutorial Broken? [message #151638 is a reply to message #151631] Tue, 13 December 2005 10:28 Go to previous messageGo to next message
Originally posted by: notsaying.nowhere.org
Forgot to mention that I am using the latest "bundle" download of wtp +
eclipse 3.1
No ZooBeansProject.jar to be found?
D:\eclipse\workspace>find . -name "*.jar"
/ZooBeansProject/.deployables/ZooBeansProject/ZooBeansProjec tClient.jar
/ZooWeb/.deployables/ZooWeb/WEB-INF/lib/ZooBeansProjectClien t.jar
Re: Tutorial Broken? [message #151681 is a reply to message #151638] Tue, 13 December 2005 11:43 Go to previous messageGo to next message
Hmm. Ok got past this issue by modifying the files :
/ZooBeansProjectEAR/.deployables/ZooBeansProjectEAR/META-INF /application.xml
and
/ZooBeansProjectEAR/ZooBeansProjectEAR/META-INF/application. xml
to point to ZooBeansProjectClient.jar instead of ZooBeansProject.jar.
However, when I go to do the last step in the tutorial, running the
test.jsp on the server, JBoss I get a null value for tiger from the
following lines:
com.zoo.TigerHome home = com.zoo.TigerUtil.getHome();
tiger = home.create();
Thoughts on the tutorial:
Prereqs : fine
Install Steps 1-10: fine, except xdoclet doesn't seem to come with the
bundle - no problem just go out and download it, install, point to it
Creating EJB and Web Modules:
Step 1: WTF? My wizzard doesn't match: Under EJB there is now "J2EE EJB
Module" only "EJB Project" or "Enterprise JavaBean" Hmmm, so I select J2EE
EJB Project instead...
Step 2: Because of Step 1, my window looks similar but not exactly the
same, so I'm creating a project instead of a module, will try to duplicate
names in tutorial - Putting "ZooBeansProject" for Project Name... But
wait? Where in blazes do I setup the ever elusive module, guess I will
have to wait...Select EJB version 2.0 so that my Jboss 3.2.3 shows up...
Trying to Deselect "Add module to an EAR application" just like tutorial
screenshot shows - WTF? Now I can't select "Create an EJB Client Jar..."
arg! What am I supposed to do now? Guessing I should select both because
it is important to create the ejb client jar for future use... Finish...
Egad! Enough already, could somebody post a _working_ tutorial?
Re: Tutorial Broken? [message #152226 is a reply to message #151681] Wed, 14 December 2005 06:58 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi !
there were some changes after M4. Now you have to create a new "Enterprise
Application" (found in the "J2EE" section of the "New"-Wizard).
A wizard appears, in step 2 (or step 3 since 1.0M9) you can add J2EE modules to
the EAR application. Here click on "New Module..." and pick the required types,
e.g. EJB module and Web Module.
Hope this helps
Wolfgang
Re: Tutorial Broken? [message #160999 is a reply to message #151631] Thu, 16 February 2006 10:25 Go to previous message
Originally posted by: arunkumar443.gmail.com
please give me solution for that one
Previous Topic:Spawning javac (newbie)
Next Topic:syntax highlighting in JSP
Current Time: Fri Apr 18 10:23:42 EDT 2025
Powered by FUDForum. Page generated in 0.03080 seconds
