Home » Eclipse Projects » Sapphire » How to hide outline from SapphireEditorForXml?
How to hide outline from SapphireEditorForXml? [message #1033874] Thu, 04 April 2013 18:48 Go to next message
Joshua Spaulding is currently offline Joshua SpauldingFriend
How do I autohide the outline from the editor when it is loaded?
Re: How to hide outline from SapphireEditorForXml? [message #1033882 is a reply to message #1033874] Thu, 04 April 2013 18:59 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
From MasterDetailsEditorPage object (that's the form page in the editor), call getPart().state().getContentOutlineState().setVisible( false ).
- Konstantin
Re: How to hide outline from SapphireEditorForXml? [message #1033895 is a reply to message #1033882] Thu, 04 April 2013 19:19 Go to previous messageGo to next message
Thanks for the response. Where and when would I call this code? My xml file is loaded from a custom navigator. The SapphireEditorForXml is associated to the content type of my xml file so I never directly call the Editor.
Re: How to hide outline from SapphireEditorForXml? [message #1033976 is a reply to message #1033895] Thu, 04 April 2013 22:00 Go to previous messageGo to next message
Maybe subclass SapphireEditorForXml, override createFormPages() and do this step in there?
Re: How to hide outline from SapphireEditorForXml? [message #1036578 is a reply to message #1033976] Mon, 08 April 2013 15:09 Go to previous messageGo to next message
Thanks. I'm getting an error though when I try to extend that class. I'm not sure this is a related issue but do you know the cause?
the hierarchy of the type <myclass> is inconsistent
Re: How to hide outline from SapphireEditorForXml? [message #1036663 is a reply to message #1036578] Mon, 08 April 2013 17:10 Go to previous messageGo to next message
This Java error typically means there is an issue with your plugin's manifest. Make sure that you included "org.eclipse.sapphire.modeling" and "org.eclipse.sapphire.ui" in your manifest's required bundles.
- Konstantin
Re: How to hide outline from SapphireEditorForXml? [message #1036704 is a reply to message #1033874] Mon, 08 April 2013 18:02 Go to previous messageGo to next message
Yes, I was missing two dependencies. To subclass SapphireEditorForXml, I had to include the following which are required by the editor:
org.eclipse.ui.forms
org.eclipse.wst.sse.ui
Thanks.
Re: How to hide outline from SapphireEditorForXml? [message #1036909 is a reply to message #1036704] Tue, 09 April 2013 00:49 Go to previous message
I ended up subclassing SapphireEditor; very similar to the PurchaseOrder example. Everything is working now. Thanks for your help.
Previous Topic:ValueProperty bind to XML text
Next Topic:Implementing multiple Services on the same Property?
Current Time: Sat Jan 18 07:32:48 GMT 2020
Powered by FUDForum. Page generated in 0.03261 seconds
