Home » Eclipse Projects » GEF » Up to date eclipse 3.0 GEF/EMF Example?
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151676 is a reply to message #151610] |
Wed, 22 September 2004 14:12 |
Can you post the compile errors? They should be really simple to fix, there
have not been any major changes in GEF 3.0.0, and there is a workbench
migration guide for going from 2.1 to 3.0
"Steve Jones" <steve@istech.demon.co.uk> wrote in message
news:cipnvc$dm1$1@eclipse.org...
> The Redbook examples will not build with eclipse-3.0.0, GEF-3.0.0 and
> EMF-2.0.0.
> Anyone know of any recent/updated GEF/EMF examples that drop straight in?
> Cheers, Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151833 is a reply to message #151676] |
Thu, 23 September 2004 14:18 |
Steve Jones Messages: 95 Registered: July 2009 |
Member |
Hi Randy,
I've not investigated any of these errors in any depth. I'm still getting up
to speed with GEF & EMF as individual frameworks.
My worry was/is that since the Redbook is now a year old and both GEF/EMF
and Eclipse have moved on that these examples may be "old stock" and
consiquently not a true reflection of current GEF/EMF thinking.
If your saying that the examples are current then I'll put some effort into
resolving the build problems.
How about putting the redbook examples in the eclipse://home/tools CVS
repository?
Cheers Steve.
ERRORS/WARNINGS for SAL330RWorkflowModel
Severity Description Resource In Folder Location Creation Time
2 The method openEditor(IEditorInput, String) in the type IWorkbenchPage is
not applicable for the arguments (IFile) WorkflowModelWizard.java
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow line 174 20
September 2004 13:47:45
1 The method FBESpec.newMethod() does not override the inherited method from
FBElementImpl since it is private to a different package. FBESpec.java
fbdk/src/fb/model line 145 10 August 2004 16:22:16
1 The static field FBEditPanel.XML should be accessed in a static way
FBEditor.java fbdk/src/fb/tools/awt/editor line 446 21 September 2004
11:16:36
1 The static field FBEditPanel.Source should be accessed in a static way
FBEditor.java fbdk/src/fb/tools/awt/editor line 448 21 September 2004
11:16:36
1 The constructor StringBufferInputStream(String) is deprecated
Sax2LibrarySource.java fbdk/src/fb/xml line 72 10 August 2004 16:22:12
1 The type StringBufferInputStream is deprecated Sax2LibrarySource.java
XMLReaderTest01.java fbdk/src/fb/xml line 137 10 August 2004 16:22:12
1 The type StringBufferInputStream is deprecated XMLReaderTest01.java
1 The type StringBufferInputStream is deprecated XMLReaderTest02.java
fbdk/src/fb/xml line 62 10 August 2004 16:22:12
1 The method reset() from the type StringBufferInputStream is deprecated
XMLReaderTest02.java fbdk/src/fb/xml line 74 10 August 2004 16:22:12
XMLReaderTest02.java fbdk/src/fb/xml line 77 10 August 2004 16:22:12
fbdk/src/fb/xml line 133 10 August 2004 16:22:12
XMLReaderTest02.java fbdk/src/fb/xml line 191 10 August 2004 16:22:12
1 The type IPluginDescriptor is deprecated NetworkEditorPlugin.java
NetworkEditor/src/com/ibm/itso/sal330r/network line 101 23 September 2004
14:41:08
1 The constructor AbstractUIPlugin(IPluginDescriptor) is deprecated
NetworkEditorPlugin.java NetworkEditor/src/com/ibm/itso/sal330r/network
line 103 23 September 2004 14:41:08
1 The method shutdown() from the type AbstractUIPlugin is deprecated
line 112 23 September 2004 14:41:08
1 The field IWorkbenchActionConstants.PRINT is deprecated
NetworkEditorActionBarContributor.java
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 58 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.UNDO is deprecated
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 83 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.REDO is deprecated
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 84 23 September
2004 14:41:08
1 The method setTitle(String) from the type WorkbenchPart is deprecated
AbstractEditorPage.java
NetworkEditor/src/com/ibm/itso/sal330r/network/editor line 101 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.DELETE is deprecated
NetworkEditor.java NetworkEditor/src/com/ibm/itso/sal330r/network/editor
line 723 23 September 2004 14:41:08
line 916 23 September 2004 14:41:08
1 The method initEReference(EReference, EClassifier, EReference, String,
String, int, int, boolean, boolean, boolean, boolean, boolean, boolean,
boolean) from the type EPackageImpl is deprecated WorkflowPackageImpl.java
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 728 20
September 2004 13:37:07
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 729 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 730 20
1 The method initEAttribute(EAttribute, EClassifier, String, String, int,
int, boolean, boolean, boolean, boolean, boolean, boolean) from the type
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 733 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 734 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 735 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 736 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 737 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 740 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 741 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 742 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 745 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 746 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 749 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 750 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 755 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 760 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 765 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 768 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 769 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 770 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 771 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 772 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 773 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 774 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 777 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 780 20
ERRORS/WARNINGS for SAL330RGEFDemoApplication
2 The method getWorkflow() is undefined for the type WorkflowEditor
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 282
23 September 2004 14:49:18
2 IFileEditorInput cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 165
2 FileEditorInput cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 189
2 Workflow cannot be resolved (or is not a valid type) for the field
WorkflowEditor.workflow WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 263
2 The method addEditorAction(EditorPartAction) in the type WorkflowEditor is
not applicable for the arguments (PrintAction) WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 356
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 441
2 SaveAsDialog cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 469
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 470
2 Workflow cannot be resolved (or is not a valid return type) for the method
getWorkflow WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 734
2 workflow cannot be resolved WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 736
2 The method gotoMarker(IMarker) is undefined for the type IEditorPart
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 777
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 791
2 The method create(IFile) is undefined for the type WorkflowEditor
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 792
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 795
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 905
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 914
2 WorkflowModelManager cannot be resolved (or is not a valid type) for the
field WorkflowEditor.modelManager WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 937
create WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 945
2 Workflow cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 947
2 modelManager cannot be resolved WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 948
2 WorkflowModelManager cannot be resolved or is not a type
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 954
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 958
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 961
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 992
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 1007
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151974 is a reply to message #151833] |
Fri, 24 September 2004 18:09 |
The authors of the example would have to do that, but we don't have
resources to maintain so many examples.
For GEF 3.1, we already have 5 different examples planned.
news:ciulif$862$1@eclipse.org...
> Hi Randy,
up
into
> repository?
> Cheers Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #154609 is a reply to message #154593] |
Tue, 19 October 2004 15:00 |
Absolutely. Please e-mail Pratik Shah with your background in EMF/Class
modeling/GEF, and the are you would like to help with. Currently, we have
the following working:
Display of packages in the outline view, which contain classes.
Display of classes, attr., oper., in the diagram
Display of inheritance, references, in the diagram
DND of a class into the diagram, which auto creates an references and
inheritance connections.
We don't have:
Property sheet support
dragging of endpoints of connections
very much palette use
Pratik can give you more details.
"David Sciamma" <david.sciamma@anyware-tech.com> wrote in message
news:cl366m$4nn$1@eclipse.org...
> I'm interested in contributing to this example. Can I help ?
> David
> >>Hi Randy,
getting
> > up
GEF/EMF
> > into
> >>repository?
> >>Cheers Steve.
> David Sciamma
> Addr : Prologue 2, Rue Ampere
> Addr : BP 87216, 31672 LABEGE Cedex
> Tel : + 33 (0)5.61.00.73.45 / +33 (0)6.27.39.43.29
> Fax : + 33 (0)5.61.00.51.46
> Anyware Technologies - http://www.anyware-tech.com
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163495 is a reply to message #163487] |
Mon, 10 January 2005 21:52 |
Pratik Shah Messages: 1077 Registered: July 2009 |
David, I will open a helpwanted bugzilla and copy you on it.
Repost from the EMF newsgroup:
The compile error in the repository has been fixed. This example is very
much in the beta stage, and lots of things remain to be done. Here's a
brief run-down:
Improvements/Missing Functionality:
- Better routing
- Properties
- Diagram's imports should probably be Ecore resource files rather than
EPackages
- Validation
- Context menus
- Support for multiple inheritance
- Direct interaction with the outline (deleting from the outline, dragging
from the palette to the outline, etc.)
- Awareness about external resource changes
- Ability to move reference labels
- Ability to rearrange operations, attributes, enumLiterals, etc.
- Documentation
Known Bugs:
- PropertySources (Two-way references do not show the properties for both
the references; undo does not work properly except for TextCellEditors; no
way to edit EParameters; and so on)
- The outline does not refresh properly if you reparent a package
Because of time constraints, we're not going to be working on this example
much anymore. However, if anybody wants to contribute to this project,
they're more than welcome. Feel free to contact me with any questions you
might have.
By the way, one thing about this example that's not apparent right away is
that if you select something in the diagram and hit Ctrl+Del it will remove
it both from the diagram as well as the ecore file.
news:cruqpe$jbd$1@www.eclipse.org...
> I'm still interesting in contributing to this example.
> We are working on a project that deals with EMF and GEF.
> What are the topics to work on ?
> Pratik Shah wrote:
> > Although this example has been publically available for some time now,
it
> > still has a few things that need to be worked on. Are you (or anybody
else
> > for that matter) interested in helping out?
> >>David
> >>>>Hi Randy,
> > getting
> >>>up
> > GEF/EMF
> >>>into
> >>>>repository?
> >>>>Cheers Steve.
> >>David Sciamma
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163822 is a reply to message #163495] |
Thu, 13 January 2005 19:05 |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82517
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:crutf3$u1t$1@www.eclipse.org...
> brief run-down:
> - Better routing
> - Properties
> EPackages
> - Validation
> - Context menus
> - Documentation
> Known Bugs:
> might have.
remove
> it
> else
> > >>David
> > >>>>Hi Randy,
> > > getting
> > >>>up
> > > GEF/EMF
effort
> > >>>into
CVS
> > >>>>repository?
> > >>>>Cheers Steve.
> > >>David Sciamma
Current Time: Thu Apr 25 22:39:58 GMT 2024
Powered by FUDForum. Page generated in 0.03999 seconds
