Home » Modeling » TMF (Xtext) » Problem Importing Other Languages
Problem Importing Other Languages [message #1033802] Thu, 04 April 2013 17:01 Go to next message
Carlo M-R is currently offline Carlo M-RFriend
I had a problem with the GenerateDSL-Workflow especially with registering the genModel files in our development environment. I have found a sort of workaround but would like to know if there's a better way:
Our Xtext languages are built with maven and therefore are structured like maven projects (src/main/java etc. and target/classes as output dir). In the mwe2 file I wanted to register the genModel files as follows:
registerGeneratedEPackage = "com.myCompany.package.myDSL.MyDSLPackage"
registerGenModelFile = "platform:/resource/com.myCompany.package.myDSL/com/myCompany/package/MyDSL.genmodel"
With this config I always got the error that the path is unmapped.
I debugged the thing and found out that the org.eclipse.emf.mwe.utils.StandaloneSetup#setScanClassPath method should register the project (com.myCompany.package.myDslDSL) and allow the workflow to find the genmodel file.
But this does not work because of the way it handles project references:
else if (!scanFolder(f)) {
        // eclipse bin folder?
	File dotProject = new File(f.getParentFile(), ".project");
	if (dotProject.exists())
		registerProject(dotProject);
In our case the given classpath entry is not the eclipse bin folder but the target/classes folder and therefore it is not sufficient to just go one directory up. I hooked in a custom StandaloneSetup for testing were i simple did the following.
   File dotProject = new File(f.getParentFile().getParentFile(), ".project");
And this did the trick. The .project file is found and the project gets successfully registered and and the genmodel file is found.
Now i'm asking if this is a bug resp. missing feature in the StandaloneSetup or if there's a configuration possibility that I'm missing.
Thanks in advance for your help
Carlo
Re: Problem Importing Other Languages [message #1033819 is a reply to message #1033802] Thu, 04 April 2013 17:24 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i guess in the case you should adopt platformUri="../../"
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
Re: Problem Importing Other Languages [message #1034310 is a reply to message #1033819] Fri, 05 April 2013 09:18 Go to previous message
thanks for your hint, but the problem is that the projects that I want to import are not in the same root folder as the project I'm executing the workflow in.
Therefore I need to have the setScanClassPath method to register my project. But unfortunately this can't handle the target/classes folder.
Previous Topic:DSL Maturing, next steps
Next Topic:Getting all instances of particular grammar class
Current Time: Sun Feb 23 02:32:42 GMT 2020
Powered by FUDForum. Page generated in 0.02140 seconds
