Home » Modeling » TMF (Xtext) » library approach and global scoping
library approach and global scoping [message #1032337] |
Tue, 02 April 2013 22:14 |
in an example DSL (not based on Xbase) I have a sort of entity program
which can refer to other entities stored in another program. I'll try
to simplify the context as much as possible.
In particular, I also provide some library files with some library
entities (library files are available in a separate bundle).
For instance these are two library files
Object.mydsl
entity Object {
String toString() {...}
String.mydsl
entity String extends Object {
if in a plugin project I set a dependency on the library bundle, Object
and String can be correctly referred and resolved.
However, since the two library files are mutually dependent, the cross
references in the library files themselves are not correctly resolved
(e.g., the "String" reference in the method "toString()" at runtime is
still a proxy, and I can't seem to force its resolution in anyway).
How could I deal with that? Should I implement a custom
LazyLinkingResource, load all library files (without crossreference
resolution) and then force the resolution?
any hint please?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: library approach and global scoping [message #1033680 is a reply to message #1032337] |
Thu, 04 April 2013 14:08 |
On 04/03/2013 12:14 AM, Lorenzo Bettini wrote:
> Hi
> Object.mydsl
> entity Object {
> String.mydsl
any clue please?
thanks in advance
Lorenzo
Re: library approach and global scoping [message #1034378 is a reply to message #1033680] |
Fri, 05 April 2013 11:13 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
I can't figure out how to answer, the question is not concrete enought
to provide a simple answer - instead it gets very big, i.e. trying to
answer how containers, visibility and linking works.
Can you describe this in more concrete terms from the point of view what
is not working?
- henrik
>> Hi
>> Object.mydsl
>> entity Object {
>> String.mydsl
> any clue please?
> thanks in advance
> Lorenzo
Re: library approach and global scoping [message #1034388 is a reply to message #1034378] |
Fri, 05 April 2013 11:26 |
I'm trying to setup a simple example (with Greetings DSL) to show the
problem...
basically if your DSL (not based on Xbase) ships some library files
(e.g., with .mydsl extension) in a plugin project, the elements of the
library files can be correctly referenced in another project (which
depends on the library project), but the elements of the library files
themselves look like they are not linked together (i.e., if an element
of a library file refers to an element of another library file, in the
same library project of course, the cross-reference is not resolved...).
hope to come up with an example soon
cheers
Lorenzo
> is not working?
> - henrik
>>> Hi
>>> Object.mydsl
>>> entity Object {
>>> String.mydsl
>> any clue please?
>> thanks in advance
>> Lorenzo
Re: library approach and global scoping [message #1034503 is a reply to message #1034388] |
Fri, 05 April 2013 14:02 |
I assume you are relying on the Xtext Java/OSGi classpath support to
link bundles together?
Maybe it is a bundle start issue - try tweaking your launch config to
ensure the "library bundle" is started. Does that make a difference?
Does a "build clean" change anything?
- henrik
> problem...
> cheers
> Lorenzo
>> is not working?
>> - henrik
>>>> Hi
>>>> Object.mydsl
>>>> entity Object {
>>>> String.mydsl
>>> any clue please?
>>> thanks in advance
>>> Lorenzo
Re: library approach and global scoping [message #1034540 is a reply to message #1034503] |
Fri, 05 April 2013 15:05 |
actually the library files are part of the runtime plug-in project for
the DSL, say org.xtext.example.mydsl, and that is part of the launch
configuration; in the launch configuration all workspace plugins are
enabled.
In the new eclipse instance, I create an example plug-in project with
Xtext nature, and add the org.xtext.example.mydsl as dependency.
Please let me stress that in the example plug-in project I can correctly
refer to elements in the library files (which are part of Plug-in
Dependencies). However, in the EMF models corresponding to the library
files, cross-references across files are not resolved.
Let me (try to) be more precise: consider these two library files (I'll
try to simplify the context, of course "extends" is a cross reference to
Entity)
FILE: lib1.mydsl
entity Object {}
entity String extends Object {}
FILE: lib2.mydsl
entity List extends Object {}
in the new eclipse instance, where these two files are in Plug-in
Dependencies, String correctly refers to Object (they are in the same
file); while List cannot refer to Object (with the debugger I can see
that the reference is still a proxy, and the corresponding URI is not
resolved).
The funny thing is that in a headless environment everything works,
since I first load all the resources (including the ones corresponding
to libraries) and then perform the validation after all resources are
loaded.
In the Eclipse context it looks like the models which correspond to
mydsl files in the Plug-in Dependencies do not support cross-references
across files...
No, nothing changes, since the LazyLinkingResources corresponding to
files in Plug-in Dependencies do not seem to be reloaded anyway...
cheers
Lorenzo
> Regards
> - henrik
>> problem...
>> cheers
>> Lorenzo
>>> is not working?
>>> - henrik
>>>>> Hi
>>>>> Object.mydsl
>>>>> entity Object {
>>>>> String.mydsl
>>>>> Object
>>>> any clue please?
>>>> thanks in advance
>>>> Lorenzo
Re: library approach and global scoping [message #1034652 is a reply to message #1034540] |
Fri, 05 April 2013 18:17 |
It works headless because you add all resources to the resource set
before linking (everything is there, no need for proxies).
It seems to work when you are in the IDE as well because you get a
proxy. That means it managed to link to something (or you would not have
a proxy IIRC). What does the proxy contain is it a valid reference? Do
you get an error if you try to resolve it?
URI uri = EcoreUtil.getURI(d.getEObjectOrProxy());
What is the URI?
This is supposed to work:
EObject x = ref.getEObjectOrProxy();
if(x.eIsProxy())
x = EcoreUtil.resolve(x, o); // o is the reference object
If that does not work, try to debug through this sequence and see where
it gives up.
Does that help, or did you already try these things. If so, then it
sounds like a bug.
- henrik
> enabled.
> Entity)
> FILE: lib1.mydsl
> entity Object {}
> FILE: lib2.mydsl
> resolved).
> loaded.
> across files...
> cheers
> Lorenzo
>> Regards
>> - henrik
>>> problem...
>>> cheers
>>> Lorenzo
>>>> is not working?
>>>> - henrik
>>>>>> Hi
>>>>>> Object.mydsl
>>>>>> entity Object {
>>>>>> String.mydsl
>>>>>> Object
>>>>> any clue please?
>>>>> thanks in advance
>>>>> Lorenzo
Re: library approach and global scoping [message #1035032 is a reply to message #1034652] |
Sat, 06 April 2013 07:50 |
yes indeed; it was clear to me, sorry if I made it sound like magic ;)
however, as far as I understand, proxies are actually installed when
resources are loaded and first lazy linked (i.e., when the contents of
file are parsed, proxies are installed for references: they are actually
then resolved when validation is run).
mh... as I said above, I think that proxies are set when the program is
parsed, aren't they?
it is a URI which ends with #xtext...
> What is the URI?
> if(x.eIsProxy())
> it gives up.
> sounds like a bug.
I had already tried most of these things, but I can't seem to solve
those references with URI which end with #xtext...
but again, this problem is for references which cross files, and when
the files are in a required bundle.
I'll try to reproduce the problem in a simpler language...
by the way, I'm using Xtext 2.4.
thanks
Lorenzo
> - henrik
>> enabled.
>> Entity)
>> FILE: lib1.mydsl
>> entity Object {}
>> FILE: lib2.mydsl
>> resolved).
>> loaded.
>> across files...
>> cheers
>> Lorenzo
>>> Regards
>>> - henrik
>>>> problem...
>>>> resolved...).
>>>> cheers
>>>> Lorenzo
>>>>> what
>>>>> is not working?
>>>>> - henrik
>>>>>>> Hi
>>>>>>> program
>>>>>>> I'll try
>>>>>>> Object.mydsl
>>>>>>> entity Object {
>>>>>>> String.mydsl
>>>>>>> Object
>>>>>>> cross
>>>>>>> resolved
>>>>>>> runtime is
>>>>>> any clue please?
>>>>>> thanks in advance
>>>>>> Lorenzo
Re: library approach and global scoping [message #1035383 is a reply to message #1035307] |
Sat, 06 April 2013 20:11 |
In case it helps, (and if IIRC), the reference object has to be an
EObject that is contained in a Resource that is in a ResourceSet.
- henrik
On 2013-06-04 19:29, Steve Kallestad wrote:
> I had a similar problem last night.
> I had a line in place to resolve proxies:
> but as it turned out, the proxy was not resolving. I checked this by
> adding a line just after the resolution logging whether or not the
> object was still a proxy.
> EObject resolved = EcoreUtil.resolve(unresolvedEObject,
> *struggledToGetRightResource*);
> logger.debug("Resolved: {}", resolved.eIsProxy());
> In my particular case, since I put the wrong variable as the second
> parameter, the resolve function was simply returning me the same proxy.
> After toying around with things for a bit, I was able to obtain the
> correct resource.
> Once I did that, the code relying on a resolved proxy worked as expected.
Re: library approach and global scoping [message #1035682 is a reply to message #1035032] |
Sun, 07 April 2013 08:07 |
here's a minimalistic example to reproduce the problem I was talking
about: https://github.com/LorenzoBettini/xtext-index-experiments
the grammar is really simple
Model:
greetings+=Greeting*;
Greeting:
HelloGreeting | RefGreeting ;
HelloGreeting:
'Hello' name=ID ('extends' parent=[HelloGreeting])? '!';
RefGreeting:
'ref' greeting=[HelloGreeting];
the main plug-in project, org.xtext.example.index.greetings, also
contains two .greetings files which can be seen as libraries (which are
exported in the MANIFEST)
StandardHello.greetings
Hello Default!
and
OtherStandardHello.greetings
Hello OtherDefault extends Default!
Hello OtherDefault2 extends OtherDefault!
note that the first greeting "OtherDefault" in the second file refers to
the greeting of the first file "Default", while the second greeting
refers to another greeting in the very same file.
Now, here's a label provider, which represents also the parent
greeting's name
class GreetingsLabelProvider extends
org.eclipse.xtext.ui.label.DefaultEObjectLabelProvider {
def text(RefGreeting ref) {
'ref: ' + ref.greeting.text
def String text(HelloGreeting hello) {
hello?.name +
if (hello.parent != null) {
" -> " + hello.parent.ensureIsResolved(hello).text
} else {
def ensureIsResolved(HelloGreeting ref, HelloGreeting context) {
if (ref.eIsProxy) {
val resolved = EcoreUtil::resolve(ref, context)
return resolved as HelloGreeting
return ref
note that it also checks whether the referred greeting is a proxy and in
case it tries to resolve it, passing as the context the main greeting
object (which is contained in a resource and a resource set).
This DSL comes with a project wizard, which creates a new plug-in
project, with Xtext nature, and which depends on
org.xtext.example.index.greetings, so that it can access the greetings
in the two library files.
Now, the example.greetings in this new project
Hello Xtext extends Default!
Hello Xtext2 extends OtherDefault!
ref Default
ref OtherDefault
ref OtherDefault2
can access greetings in the libraries; however, the greetings in the
library files are not completely resolved: let me show the library files
again
Hello Default!
Now, "OtherDefault extends Default", and "Default" is not resolved (it
is defined in the other library file): it is a proxy
platform:/resource/.org.eclipse.jdt.core.external.folders/.link2/org/xtext/example/index/greetings/lib/OtherStandandHello.greetings#xtextLink_::0.0.0::1::/8
and it is marked as unresolved proxy in LazyLinkingResource.
You can try yourself, or take a look at the outline view in this screenshot
http://imageshack.us/a/img145/1928/helloindexide.png
"null" basically means that the reference is a proxy and there's no way
to resolve it.
After a long session of debugging, I think that what happens is that
when a dsl file is loaded from a dependency project (a plug-in
dependency), the global scope provider, when it accesses the Index, it
does not see its own container project as a visible container, thus, in
this case, OtherStandardHello.greetings does not see
StandardHello.greetings and thus, "Default" remains unresolved.
I hope the context and the symptoms are clear now
cheers
Lorenzo
Current Time: Tue Apr 23 12:17:48 GMT 2024
Powered by FUDForum. Page generated in 0.03358 seconds
