Home » Eclipse Projects » NatTable » Strange behavior with RowResizeCommand
Strange behavior with RowResizeCommand [message #1032241] Tue, 02 April 2013 19:08 Go to next message
Joachim Fuchs is currently offline Joachim FuchsFriend
Member
I just tried out the row resize feature and it went pretty well. The code draws a nattable and two buttons. The lower button is responsible for resizing of the selected row. This is done in a thread because I wanted to check out some 'animation'. Using 2 as a step width (see the variable) works fine. The row grows or shrinks and cell selection still works. Using 3 for the step width breaks it: the button is now useless nad it is not possible to select a cell, the selected row grows instead.
Where is the problem? Is it my code or my approach wit hthe animation? Is it a bug somewhere? I'm running Ubuntu here and the latest nattable build from the p2 repo.
Thanks for your help.
J
public class NatTable01 {
	private NatTable natTable;
	private DataLayer bodyDataLayer;
	private Button btnRowHeight;
	private ILayerCell selectedCell;
	private int step = 1;
// FINDME setting rowHeightNormal to 0 results in grid only painted table experience
	private int rowHeightNormal = 20;
	private int rowHeightBig = 77;
	private int timerdelay = 5;
		Display d = Display.getDefault();
		Shell s = new Shell(d, SWT.CLOSE | SWT.RESIZE | SWT.DOUBLE_BUFFERED);
		NatTable01 nt = new NatTable01();
		nt.createControl(s);
		s.open();
		while (!s.isDisposed()) {
			if (!d.readAndDispatch()) {
				d.sleep();
		d.dispose();
	public NatTable01() {
	public void createControl(Composite parent) {
		parent.setLayout(new GridLayout(1, false));
		final DummyBodyDataProvider bodyDataProvider = new DummyBodyDataProvider(5, 5);
		bodyDataLayer = new DataLayer(bodyDataProvider);
		final DefaultBodyLayerStack bodyLayer = new DefaultBodyLayerStack(bodyDataLayer);
		final SelectionLayer selectionLayer = bodyLayer.getSelectionLayer();
		selectionLayer.addLayerListener(new ILayerListener() {
			public void handleLayerEvent(ILayerEvent event) {
				System.out.println(event);
				if (event instanceof CellSelectionEvent) {
					CellSelectionEvent cse = (CellSelectionEvent) event;
					ILayerCell selectedCell = natTable.getCellByPosition(cse.getColumnPosition(), cse.getRowPosition());
					if (selectedCell != null) {
						setSelectedCell(selectedCell);
				} else if (event instanceof ColumnSelectionEvent) {
					setSelectedCell(null);
				} else if (event instanceof RowSelectionEvent) {
		final FreezeLayer freezeLayer = new FreezeLayer(selectionLayer);
		final CompositeFreezeLayer compositeFreezeLayer = new CompositeFreezeLayer(freezeLayer,
				bodyLayer.getViewportLayer(), selectionLayer);
		// Column header
		final IDataProvider columnHeaderDataProvider = new DummyColumnHeaderDataProvider(bodyDataProvider);
		final ILayer columnHeaderLayer = new ColumnHeaderLayer(new DefaultColumnHeaderDataLayer(
				columnHeaderDataProvider), compositeFreezeLayer, selectionLayer);
		// Row header
		final IDataProvider rowHeaderDataProvider = new DefaultRowHeaderDataProvider(bodyDataProvider);
		final ILayer rowHeaderLayer = new RowHeaderLayer(new DefaultRowHeaderDataLayer(rowHeaderDataProvider),
		// Corner
		final DefaultCornerDataProvider cornerDataProvider = new DefaultCornerDataProvider(columnHeaderDataProvider,
				rowHeaderDataProvider);
		final CornerLayer cornerLayer = new CornerLayer(new DataLayer(cornerDataProvider), rowHeaderLayer,
				columnHeaderLayer);
		// Grid
		final GridLayer gridLayer = new GridLayer(compositeFreezeLayer, columnHeaderLayer, rowHeaderLayer, cornerLayer);
		natTable = new NatTable(parent, gridLayer, false);
		ColumnLabelAccumulator columnLabelAccumulator = new ColumnLabelAccumulator() {
			public void accumulateConfigLabels(LabelStack configLabels, int columnPosition, int rowPosition) {
				super.accumulateConfigLabels(configLabels, columnPosition, rowPosition);
				configLabels.addLabelOnTop("LABEL");
		bodyDataLayer.setConfigLabelAccumulator(columnLabelAccumulator);
		// Configuration
		natTable.addConfiguration(new DefaultNatTableStyleConfiguration() {
			public void configureRegistry(IConfigRegistry configRegistry) {
				super.configureRegistry(configRegistry);
				configRegistry.registerConfigAttribute(CellStyleAttributes.VERTICAL_ALIGNMENT,
						VerticalAlignmentEnum.TOP, DisplayMode.NORMAL, "LABEL");
		natTable.addConfiguration(new HeaderMenuConfiguration(natTable));
		natTable.addConfiguration(new DefaultFreezeGridBindings());
		// ADD BODY CONTEXT MENU CONFIG
		natTable.addConfiguration(new BodyMenuConfiguration(natTable, selectionLayer));
		natTable.configure();
		natTable.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
		Button btnResize = new Button(parent, SWT.PUSH);
		btnResize.setText("Resize");
		btnResize.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				for (int i = 0; i < bodyDataLayer.getRowCount(); i++) {
					bodyDataLayer.doCommand(new RowResizeCommand(bodyDataLayer, i, (int) (bodyDataLayer
							.getRowHeightByPosition(i) * 1.1)));
		btnRowHeight = new Button(parent, SWT.PUSH);
		btnRowHeight.setText("Change Row Height");
		btnRowHeight.setEnabled(false);
		btnRowHeight.addSelectionListener(new SelectionAdapter() {
				int currentRowHeight = bodyDataLayer.getRowHeightByPosition(selectedCell.getRowPosition());
				BiggerSmallerRunner bsr = new BiggerSmallerRunner();
				bsr.cell = selectedCell;
				if (currentRowHeight == rowHeightBig) {
					bsr.targetSize = rowHeightNormal;
				} else {
					bsr.targetSize = rowHeightBig;
				timer.scheduleAtFixedRate(bsr, 0, timerdelay);
				selectionLayer.setSelectedCell(selectedCell.getColumnPosition(), selectedCell.getRowPosition());
	Timer timer = new Timer();
	class BiggerSmallerRunner extends TimerTask {
		ILayerCell cell;
		int targetSize;
		public void run() {
			natTable.getDisplay().asyncExec(new Runnable() {
				public void run() {
					int currentRowHeight = bodyDataLayer.getRowHeightByPosition(cell.getRowPosition());
					if (targetSize + step < currentRowHeight) {
						bodyDataLayer.doCommand(new RowResizeCommand(bodyDataLayer, cell.getRowPosition(),
								currentRowHeight - step));
					} else if (targetSize - step > currentRowHeight) {
								currentRowHeight + step));
					} else if (currentRowHeight + step >= targetSize) {
						bodyDataLayer.doCommand(new RowResizeCommand(bodyDataLayer, cell.getRowPosition(), targetSize));
						cancel();
	protected void setSelectedCell(ILayerCell selectedCell) {
		this.selectedCell = selectedCell;
		btnRowHeight.setEnabled(this.selectedCell != null);
[Updated on: Thu, 04 April 2013 08:39]
Report message to a moderator
Re: Strange behavior with RowResizeCommand [message #1033380 is a reply to message #1032241] Thu, 04 April 2013 07:20 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
I'm not sure, but it seems to be more related to your code. Maybe some calculation issue with your member variables in the background processing.
Re: Strange behavior with RowResizeCommand [message #1033415 is a reply to message #1033380] Thu, 04 April 2013 08:02 Go to previous messageGo to next message
Member
You are right, the problem sat there.
BTW, if I set a single row's height to 0 none of the table cells are being painted, only the grid lines are left. Is that intended behavior?
Thank you.
J
Re: Strange behavior with RowResizeCommand [message #1033437 is a reply to message #1033415] Thu, 04 April 2013 08:16 Go to previous messageGo to next message
The table cells of that row or all table cells in the whole table? For the first one I would say that's intended because the height of 0 should show nothing. The last one might be a bug. Do you have a screenshot or example? But I would rather hide or filter a row instead of setting the height to 0. Wink
Re: Strange behavior with RowResizeCommand [message #1033459 is a reply to message #1033437] Thu, 04 April 2013 08:43 Go to previous messageGo to next message
Member
Yes, the whole table including all headers is affected. I modified the code in the starting post. Set the FINDME variable to 0 to reproduce.
J
Dirk Fauth wrote on Thu, 04 April 2013 10:16
Re: Strange behavior with RowResizeCommand [message #1033464 is a reply to message #1033459] Thu, 04 April 2013 08:49 Go to previous messageGo to next message
Ok, seems to be a bug in rendering. Possibly because of some issues with calculations regarding the 0 in somewhere. Please file a bug.
Re: Strange behavior with RowResizeCommand [message #1033490 is a reply to message #1033464] Thu, 04 April 2013 09:28 Go to previous message
Member
https://bugs.eclipse.org/bugs/show_bug.cgi?id=404880
J
Previous Topic:Row selection when right clicking row header
Next Topic:Selected columns indexes in collapsed groups
Current Time: Sun Sep 26 09:24:24 GMT 2021
Powered by FUDForum. Page generated in 0.02254 seconds
