Re: WindowBuilder encountered unexpected internal error [message #1032821 is a reply to message #1032160] |
Wed, 03 April 2013 13:25 |
shank b Messages: 2 Registered: April 2013 |
Hi Eric , thank you for the response.
My previous procedure as you mentioned didn't work but something u mention i kinda did go ahead with . I uninstalled the plugin and all the dependencies and reinstalled an older version of the same plugin and it WORKED ! I work with 2 copies of the same IDE just to test out new plugins and sync my repositories for various reason like this and it worked on both my copies . Just to be on the safe side i did removed the update for this plug in one of my IDE copies to test it further .
[Updated on: Wed, 03 April 2013 13:28] Report message to a moderator
Re: WindowBuilder encountered unexpected internal error [message #1042586 is a reply to message #1031724] |
Tue, 16 April 2013 16:05 |
Frederic Filiatrault Messages: 8 Registered: April 2013 |
One thing I don't understand is that when installing a fresh copy of WindowBuilder Pro, it installs 1.5.0 (Except for the GWT tools, which are up to date at 2.6.0). Doing an update right after the installation and it goes to 1.5.2 (Except for WindowBuilder CSS Support thatstays on 1.5.0)
1.5.2 is not working for me actually. On the design view, it goes to 4 different error msgs, each of them when I click on the reparse button. The 4th one stays
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.NoClassDefFoundError: org/eclipse/wb/internal/core/editor/EditorLifeCycleListener
(REPARSE)
java.lang.NoClassDefFoundError: org/eclipse/wb/internal/core/model/description/resource/IDescriptionVersionsProviderFactory
(REPARSE)
org.eclipse.core.runtime.CoreException: Plug-in "com.google.gdt.eclipse.designer" was unable to instantiate class "com.google.gdt.eclipse.designer.ToolkitProvider".
(REPARSE)
org.eclipse.wb.internal.core.utils.check.AssertionFailedException: Can not find description for toolkit: org.eclipse.wb.swing
This is a JUNO version. I've tried to clean installation of JUNO on separate workspace. Any ideas?
FUDForum. Page generated in 0.02498 seconds
