Home » Archived » EPF » RACI Model in EPF
RACI Model in EPF [message #1029284] Fri, 29 March 2013 08:37 Go to next message
Hi Guys
I need somebody who can help me to customize EPF to support the RACI Model for a task,
R- Responsible
A- Accountable
C- Contribute
I- Inform
Right now we have only Responsible(In EPF as Primary Perform) and Contribute (In EPF as Additional Performs).
So I need to add for a task Accountable and Inform.
Is this customization available ?
Who can help me?
Has somebody the same need ?
Thank you,
Gabriel
Re: RACI Model in EPF [message #1118820 is a reply to message #1029284] Fri, 27 September 2013 16:33 Go to previous messageGo to next message
Hello Gabriel,
I have the same problem. I need to create the RACI model in EPF, but as you said it is not supported yet. I see only Primary Performers (Responsible for ) and Additional Performers.
Have you found the solution to this problem? I found one document where Eclipse was talking about the new features of EPF (in 2007) and that RACI model should be one of them. But, I do not know if this happened or it will happen in the near future.
I would appreciate it very much if you can help.
Thank you!
Vesna.
Re: RACI Model in EPF [message #1121064 is a reply to message #1118820] Mon, 30 September 2013 04:22 Go to previous messageGo to next message
No solution yet. I have also RMC (comercial version of EPF)but is not working to add the accountable and inform roles. I need to contact IBM for support.
Re: RACI Model in EPF [message #1124640 is a reply to message #1121064] Thu, 03 October 2013 15:04 Go to previous messageGo to next message
Thank you Gabriel!
Good luck Smile
Vesna.
Re: RACI Model in EPF [message #1126582 is a reply to message #1124640] Sat, 05 October 2013 14:50 Go to previous messageGo to next message
Hi Gabriel - please keep us posted on the forum with the response from IBM.
Many thanks,
Chris
Re: RACI Model in EPF [message #1181833 is a reply to message #1126582] Mon, 11 November 2013 16:47 Go to previous messageGo to next message
RACI is supported in RMC, but not EPF.
RACI is essentially a named relationship between a role and a task or work product.
RMC/EPF has one relationship between a role and work product (responsible)
and two between role and task (performing and supporting if memory serves).
To implement RACI in RMC, you can add new relationships as described here:
http://pic.dhe.ibm.com/infocenter/rmchelp/v7r5m2/topic/com.ibm.rmc.help.doc/topics/t_create_custom_method_content.html
You could also reuse the existing relationships, renaming them as needed in a custom skin (another RMC-only feature).
Re: RACI Model in EPF [message #1182459 is a reply to message #1181833] Tue, 12 November 2013 02:41 Go to previous messageGo to next message
I tested and is working in RMC to add aditional roles.
But my challange is to display them in the relationship table. They are disply in a new section called "Additional Roles" under "Relationship" section.
Can anybody help me here ?
Gabriel
Re: RACI Model in EPF [message #1272760 is a reply to message #1182459] Tue, 18 March 2014 13:46 Go to previous message
The tables presented by the webpage can be modified using the RMC skins feature.
See https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/W6b0a089a62f3_4493_bcc1_ebe60a2ebb41/page/Customizing%20with%20Skins
Previous Topic:OpenUP project example
Next Topic:EPF Composer - Activity Diagram Editor fail to open
Current Time: Sat May 24 13:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.05004 seconds
