Re: xtext integration with gmf [message #1045574 is a reply to message #1032711] |
Sat, 20 April 2013 13:45 |
serhat gezgin Messages: 243 Registered: January 2013 Location: Izmir |
Hi all
I use this steps and my senchronization work perfect but when i generate my first
diagram from xtext program i always get error (error log attached as a error.txt file)
(But only first iteration i get this error on second or later iteration i dont get this error.)
first part of error ;
!ENTRY org.eclipse.osgi 2 0 2013-04-21 01:42:55.171
!MESSAGE The activator org.eclipse.gmf.examples.runtime.diagram.decorator.DecoratorPlugin for bundle org.eclipse.gmf.examples.runtime.diagram.decorator is invalid
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.gmf.examples.runtime.diagram.decorator.DecoratorPlugin for bundle org.eclipse.gmf.examples.runtime.diagram.decorator is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:236)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.gmf.runtime.common.core.service.Service$ProviderDescriptor.getProvider(Service.java:158)
at org.eclipse.gmf.runtime.diagram.ui.internal.services.decorator.DecoratorService$ProviderDescriptor.provides(DecoratorService.java:72)
at org.eclipse.gmf.runtime.common.core.service.Service.safeProvides(Service.java:859)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy.getUncachedProviders(ExecutionStrategy.java:254)
at org.eclipse.gmf.runtime.common.core.service.Service.getProviders(Service.java:537)
at org.eclipse.gmf.runtime.common.core.service.ExecutionStrategy$4.execute(ExecutionStrategy.java:178)
at org.eclipse.gmf.runtime.common.core.service.Service.execute(Service.java:651)
at org.eclipse.gmf.runtime.diagram.ui.internal.services.decorator.DecoratorService.createDecorators(DecoratorService.java:121)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.DecorationEditPolicy.refresh(DecorationEditPolicy.java:184)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$3.run(GraphicalEditPart.java:858)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refresh(GraphicalEditPart.java:851)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.addChild(GraphicalEditPart.java:1319)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.handleNotificationEvent(GraphicalEditPart.java:1464)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.notifyChanged(GraphicalEditPart.java:1438)
at org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.fireNotification(DiagramEventBroker.java:504)
at org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.resourceSetChanged(DiagramEventBroker.java:399)
at org.eclipse.gmf.runtime.diagram.ui.DiagramEventBrokerThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe.java:73)
at org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFactory$DiagramEditingDomain.postcommit(DiagramEditingDomainFactory.java:214)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:543)
at org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
at org.eclipse.emf.workspa
But only one i get this error on second or later iteration i dont get this error.
Anyone can help me to solve this eror ?
Attachment: error.txt
(Size: 82.37KB, Downloaded 316 times)
[Updated on: Sat, 20 April 2013 13:49] Report message to a moderator
FUDForum. Page generated in 0.02740 seconds
