Home » Eclipse Projects » GEF » GEF 3.0.1 Create Pallete Error
GEF 3.0.1 Create Pallete Error [message #150016] Tue, 07 September 2004 21:17 Go to next message
Originally posted by: jsk_lam.hotmail.com
I just installed the Cascade drop 3 and try to run the redbook GEF example
NetworkModel ( chapter 5), I got the error of Unable to create part. It
works fine on the GEF 3.0.0 (05-13-2004 build or Cascade 3.0 drop 2 build.)
The problem is in lines are:
CreationToolEntry entry;
entry = new CreationToolEntry("Node", "Create a node", new
ModelCreationFactory(Node.class), null, null);
add(entry); // This line causes the exception !!!!!
The exception is in the org.eclipse.gef.palette.PaletteContainer.java:
add (int index, PaletteEntry enty) {
if (!acceptsType(entry.getType()))
throw new IllegalArgumentException(
"This container can not contain this type of child: " +
entry.getType());
List oldChildren = new ArrayList(getChildren());
I debug the same code with Cascade I2, the same add() method in I2 didn't
have the acceptsType() test, and it is simply:
How to fix and make the code work in I3?
Best Regards,
SL
Re: GEF 3.0.1 Create Pallete Error [message #150036 is a reply to message #150016] Wed, 08 September 2004 03:06 Go to previous messageGo to next message
GEF 3.0.0 was released on 06-25-2004. You should have the same behavior on
both 3.0.0 and 3.0.1
The solution is to create either a group or a drawer to contain the entry.
"SL" <jsk_lam@hotmail.com> wrote in message news:chl8hk$jd9$1@eclipse.org...
build.)
> entry.getType());
> Best Regards,
> SL
Re: GEF 3.0.1 Create Pallete Error [message #150075 is a reply to message #150036] Wed, 08 September 2004 16:47 Go to previous messageGo to next message
I actually have 2 version of GEF 3.0.0 and the earlier one works but the
later one has exactly the same behavior as you mentioned. Is there a
simple example on how to create either a group or a drawer for the
pallete? Thanks.
SL
> > Hi,
> build.)
> > entry.getType());
> > Best Regards,
> > SL
Re: GEF 3.0.1 Create Pallete Error [message #150093 is a reply to message #150075] Wed, 08 September 2004 19:37 Go to previous message
From my reply to your previous post:
So, to fix this problem, create a group or drawer and put the tools inside
that. Look at LogicPlugin#createPalette() if you are not sure how to do
that.
"SL" <jsk_lam@hotmail.com> wrote in message news:chnd31$uqj$1@eclipse.org...
> pallete? Thanks.
> SL
on
entry.
> > > Hi,
example
It
> > build.)
> > > entry.getType());
didn't
> > > Best Regards,
> > > SL
Previous Topic:Dropdown toolbar button
Next Topic:CommandStacks in GEF
Current Time: Mon Feb 17 18:55:53 GMT 2025
Powered by FUDForum. Page generated in 0.03276 seconds
