Virgo 3.6.1 admin console/ssh issues [message #1023980] |
Mon, 25 March 2013 15:31 |
James Gartner Messages: 30 Registered: March 2012 |
Member |
Folks, I just installed a new Virgo 3.6.1 jetty installation, and I have started it up.
When I go to the admin console (http://localhost:8080/admin)it works fine, but if I use that actual MACHINE name, (http://machinename:8080/admin) it only shows the Host information page, with NO Tabs (I can't see the "Overview, Artifacts, Repositories, etc. across the tab bar).
If I go from a REMOTE machine using that http://machinename:8080/admin, I STILL don't see the tabs.
In addition, I have changed the repository/ext/osgi.console.properties to allow ssh, and yet when I try to ssh in, I get "Connection refused". This DOES work on a virgo jetty 3.0.3 install I have on the same machine (they are NOT both up at the same time). I have tried changing the port (2512), but still doesn't work (telnet doesn't either).
Any ideas???
Re: Virgo 3.6.1 admin console/ssh issues [message #1029435 is a reply to message #1029389] |
Fri, 29 March 2013 17:39 |
Florian Waibel Messages: 166 Registered: June 2010 |
James Gartner wrote on Fri, 29 March 2013 12:07BTW, netstat -a clearly shows nothing listening on the 2511 or 2512 port with my 3.6.1.RELEASE installation.
When I bring up my 3.0.3.RELEASE, it does show it listening (on 2501 and 2502)and I can connect.
From the snippet you posted I'd expect Virgo listening on 2411 and 2412. Maybe this is as simple as an off by 100 error...
[Updated on: Fri, 29 March 2013 17:40] Report message to a moderator
Re: Virgo 3.6.1 admin console/ssh issues [message #1031522 is a reply to message #1029435] |
Mon, 01 April 2013 22:15 |
Member |
OK, I had changed a setting in the java6-server.profile and it LOOKS like I am now getting the ports to be listened to at 2411, 2412, 2511, 2512, and I CAN telnet/SSH.
However, if I comment out the telnet.host and/or the ssh.host in the properties files, it does NOT show those ports being listened to. I used to do this in the old 3.0.3.RELEASE to allow ssh from OTHER systems. I also tried
ssh.host=*, but that didn't work either.
If I use the actual MACHINE name, it appears to not listen on the ports either. The only way I get this to work is if those are set to "localhost".
Is there any way to do this like the older system allowed?
FUDForum. Page generated in 0.03152 seconds
