syntax error near unexpected token.... [message #1023929] |
Mon, 25 March 2013 13:33 |
Alessandro Saracino Messages: 4 Registered: March 2013 |
Hi, I've problem with hudson installation.
I've an AWS INSTANCE withs SMALL configuration and Amazon Linux AMI 2012.09.1
I've installed HUDSON with this command:
sudo wget -O /etc/yum.repos.d/hudson.repo http:// hudson-ci.org/redhat/hudson.repo
sudo yum check-update
sudo yum install hudson
After this command, I lunched
service hudson
and it give me this error:
/etc/init.d/hudson: line 120: syntax error near unexpected token `('
/etc/init.d/hudson: line 120: ` echo "${attn} Use try-restart ${done}(LSB)${attn} rather than condrestart ${warn}(RH)${norm}"'
Obviously HUDSON not run....
What's my error?
[Updated on: Tue, 26 March 2013 14:31] Report message to a moderator
FUDForum. Page generated in 0.03112 seconds
