Exception in BIRT engine logged [message #1023157] |
Sat, 23 March 2013 12:33 |
donino donino Messages: 183 Registered: July 2011 |
Hi everybody,
We use the BIRT engine API 4.2.1, on a prod server we have about 30 reports. For example in the birt engine log we can see this kind of warning, probably due to a Math.floor or something like this in a report script:
Mar 23, 2013 9:39:40 AM org.eclipse.birt.core.format.NumberFormatter format
WARNING: null
java.lang.NumberFormatException
at java.math.BigDecimal.<init>(BigDecimal.java:470)
at java.math.BigDecimal.<init>(BigDecimal.java:739)
at java.math.BigDecimal.valueOf(BigDecimal.java:1069)
at org.eclipse.birt.core.format.NumberFormatter.roundValue(NumberFormatter.java:637)
at org.eclipse.birt.core.format.NumberFormatter.format(NumberFormatter.java:332)
at org.eclipse.birt.core.format.NumberFormatter.format(NumberFormatter.java:393)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.format(LocalizedContentVisitor.java:371)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processData(LocalizedContentVisitor.java:319)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeData(LocalizedContentVisitor.java:292)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:161)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layoutChildren(HTMLGroupLM.java:117)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:661)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
My question is not specific to this very issue. The problem is, when a such exception occurs we don't have clues about which report is involved,nore the report parameters map. If we increase the logging level to FINE, logs become huge and it's hard to find out what's happening in a multithread context. Is there a way to log some context informations when a warning/severe exception happens? If not, would it be a good enhancement request?
Thanks!
[Updated on: Sat, 23 March 2013 12:35] Report message to a moderator
FUDForum. Page generated in 0.01431 seconds
