Home » Modeling » EMF » Problem with persistence....
Problem with persistence.... [message #1022830] Fri, 22 March 2013 15:54 Go to next message
Milan Djukic is currently offline Milan DjukicFriend
Hi!
I have a problem in persistin an emf model. The code is:
ResourceSet resourceSet=new ResourceSetImpl();
URI file=URI.createFileURI(new File("test.xmi").getAbsolutePath());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi",
				new XMIResourceFactoryImpl());
Resource resource = resourceSet.createResource(file);
resource.getContents().add(object_to_persist);
Program crashes when come to resource.getContents().add(). Can anyone tell me what is a problem?
Re: Problem with persistence.... [message #1022895 is a reply to message #1022830] Fri, 22 March 2013 18:36 Go to previous messageGo to next message
problem is in EcorePackage.Literals.EATTRIBUTE. Value is null.
Why is null?
This attribute is requested while trying to add object in list.
resource.getContents() is OK. but resource.getContents().add NOT OK.
[Updated on: Fri, 22 March 2013 19:49]
Report message to a moderator
Re: Problem with persistence.... [message #1022996 is a reply to message #1022895] Sat, 23 March 2013 00:47 Go to previous messageGo to next message
Milan,
So did you answer your own question or you still have a question? Please
include stack traces...
On 22/03/2013 7:36 PM, Milan Djukic wrote:
> problem is in epackage in method geteAttribute. value is null.
Ed Merks
Re: Problem with persistence.... [message #1023103 is a reply to message #1022830] Sat, 23 March 2013 08:47 Go to previous messageGo to next message
Yes i still have a question.I can't figure out where is an error.
Exception in thread "main" java.lang.ExceptionInInitializerError
	at org.eclipse.emf.ecore.impl.EPackageImpl.eStaticClass(EPackageImpl.java:236)
	at org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eClass(MinimalEObjectImpl.java:678)
	at org.eclipse.emf.ecore.impl.ENamedElementImpl.eContents(ENamedElementImpl.java:224)
	at org.eclipse.emf.ecore.util.EcoreUtil$ProperContentIterator.<init>(EcoreUtil.java:1289)
	at org.eclipse.emf.ecore.util.EcoreUtil$4.getChildren(EcoreUtil.java:1200)
	at org.eclipse.emf.ecore.util.EcoreUtil$ContentTreeIterator.hasNext(EcoreUtil.java:1451)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.attached(ResourceImpl.java:852)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsEList.inverseAdd(ResourceImpl.java:408)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:312)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
	at org.eclipse.emf.ecore.impl.EPackageImpl.createResource(EPackageImpl.java:748)
	at org.eclipse.emf.ecore.impl.EcorePackageImpl.initializePackageContents(EcorePackageImpl.java:2810)
	at org.eclipse.emf.ecore.impl.EcorePackageImpl.init(EcorePackageImpl.java:485)
	at org.eclipse.emf.ecore.EcorePackage.<clinit>(EcorePackage.java:67)
	at org.eclipse.emf.ecore.impl.EPackageImpl.<init>(EPackageImpl.java:185)
	at pokusaj.impl.PokusajPackageImpl.<init>(PokusajPackageImpl.java:58)
	at pokusaj.impl.PokusajPackageImpl.init(PokusajPackageImpl.java:84)
	at pokusaj.PokusajPackage.<clinit>(PokusajPackage.java:55)
	at pokusaj.PokusajPackage$Literals.<clinit>(PokusajPackage.java:235)
	at pokusaj.impl.AImpl.eStaticClass(AImpl.java:70)
	at org.eclipse.emf.ecore.impl.EObjectImpl.eClass(EObjectImpl.java:263)
	at org.eclipse.emf.ecore.util.EContentsEList.createEContentsEList(EContentsEList.java:49)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eContents(BasicEObjectImpl.java:815)
	at test.Test.main(Test.java:39)
	at org.eclipse.emf.ecore.EcorePackage$Literals.<clinit>(EcorePackage.java:5107)
	... 31 more
Re: Problem with persistence.... [message #1023143 is a reply to message #1023103] Sat, 23 March 2013 11:39 Go to previous messageGo to next message
ExceptionInInitializerError problems are usually much further up the
stack, and often end up telling you that you didn't do a rebuild.
Right at the end of your list
at
... 31 more
is clearly very smelly, and very unlikely to be the true problem.
Run under the debugger with at least NPE, CCE, IOE AIOOBE caught, and
beware that the debugger normally steps over hidden class initialization
which is where your trouble is.
Ed Willink
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 31 more
Re: Problem with persistence.... [message #1023149 is a reply to message #1023143] Sat, 23 March 2013 11:59 Go to previous messageGo to next message
Given it's a stand alone test case and that package initialization is
generally delayed as long as possible, it's likely that the delayed
package initializing itself is causing a problem. Likely doing
PokusajPackage.eINSTANCE.eClass() to force initialization at the start
of main would avoid this, and this is also necessary in other scenarios,
e.g., when the first thing you do is load an instance file, the package
needs to be registered, and the suggested idiom does that as a side effect.
On 23/03/2013 7:39 AM, Ed Willink wrote:
> Hi
> at
> ... 31 more
> initialization which is where your trouble is.
> Regards
> Ed Willink
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 31 more
Ed Merks
Re: Problem with persistence.... [message #1023164 is a reply to message #1023149] Sat, 23 March 2013 13:00 Go to previous messageGo to next message
@Ed Willink
I don't understand you. What is NPE, CCE, IOE AIOOBE?
@Ed Merks
Tried that. It's the same exception...
Re: Problem with persistence.... [message #1023169 is a reply to message #1023164] Sat, 23 March 2013 13:15 Go to previous messageGo to next message
Milan,
Comments below.
On 23/03/2013 9:00 AM, Milan Djukic wrote:
> @Ed Willink
NullPointerException, ClassCastException, IndexOfBoundsException,
ArrayIndexOutOfBoundsException.
I doubt these other things are the cause though. Your stack trace is
quite complete all the way down to main...
> @Ed Merks
But does the exception happen during that new call? I.e., is the stack
trace the same? Try EcorePackage.eINSTANCE.eClass() as the first thing
then, i.e., before you initialize your package. If you have problems,
please show the stack trace.
Ed Merks
Re: Problem with persistence.... [message #1023179 is a reply to message #1023169] Sat, 23 March 2013 14:04 Go to previous messageGo to next message
Hm.. Now problem is in EcorePackage.eINSTANCE.eClass() or PokusajPackage.eINSTANCE.eClass(); What ever i put throws the same exception.
But when i try to debug this line, debugger do nothing. If i press F5 or F6 debugger just do nothing...
Like before value EcorePackage.Literals.EATTRIBUTE is null. When i run program here crashes.
Here stack trace in case PokusajPackage.eINSTANCE.eClass();
	at test.Test.main(Test.java:27)
	... 19 more
Here stack trace in case EcorePackage.eINSTANCE.eClass();
	at test.Test.main(Test.java:28)
	... 15 more
Re: Problem with persistence.... [message #1023249 is a reply to message #1023179] Sat, 23 March 2013 19:03 Go to previous messageGo to next message
Here's whole eclipse project. It's simple. So if someone have a little time to try to find where is an error.
Class names are different then above.
  • Attachment: Test.rar
    (Size: 157.06KB, Downloaded 176 times)
[Updated on: Sat, 23 March 2013 19:04]
Re: Problem with persistence.... [message #1023310 is a reply to message #1023249] Sat, 23 March 2013 23:10 Go to previous messageGo to next message
Milan,
There's no .project file in there. Try invoking Generate Test Code and
running the XyzExample.java.
Ed Merks
Re: Problem with persistence.... [message #1023347 is a reply to message #1023310] Sun, 24 March 2013 01:54 Go to previous messageGo to next message
How? There is .project file.
Neither that working Sad. I invoke generate test code and run TestExample.java:
	at test.impl.TestPackageImpl.<init>(TestPackageImpl.java:54)
	at test.impl.TestPackageImpl.init(TestPackageImpl.java:80)
	at test.TestPackage.<clinit>(TestPackage.java:56)
	at test.tests.TestExample.main(TestExample.java:55)
	... 19 more
Who is crazy here Smile
Maybe i need to set something in framework....
[Updated on: Sun, 24 March 2013 01:56]
Re: Problem with persistence.... [message #1023384 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
Sorry but Eclipse says no projects found in this file. I'm not sure
what's wrong with it. Are you able to import it yourself?
> Neither that working :(. I invoke generate test code and exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
> Who is crazy here :)
Ed Merks
Re: Problem with persistence.... [message #1023386 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023388 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023390 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023392 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023394 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023396 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023398 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023400 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023402 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023404 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023406 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023408 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023410 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023412 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023414 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023416 is a reply to message #1023347] Sun, 24 March 2013 04:45 Go to previous messageGo to next message
Milan,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 19 more
Ed Merks
Re: Problem with persistence.... [message #1023459 is a reply to message #1023416] Sun, 24 March 2013 09:23 Go to previous message
Wow how many duplicate posts Very Happy
I did it!!!! I make a new project with just one class and one attribute, and now working Very Happy. Maybe problem is in model. Now i will see.
Thanks for everithing!
Previous Topic:Abstract item provider class
Next Topic:[xcore] xcore Editor crashes with xText 2.4
Current Time: Thu Mar 28 09:49:05 GMT 2024
Powered by FUDForum. Page generated in 0.08723 seconds
