Home » Eclipse Projects » GEF » 2 Property views?
2 Property views? [message #149081] Mon, 30 August 2004 20:40 Go to next message
Originally posted by: none.bphnx.com
Is is possible to create 2 properties views for a figure? For example, for
each figure I have a view model (size, location, etc.) and a business
model (business stuff), and I want to be able to change each models
attributes via 2 separate properties views. Is this possible?
thank you,
B
Re: 2 Property views? [message #149105 is a reply to message #149081] Mon, 30 August 2004 23:24 Go to previous messageGo to next message
B,
Check out the IBM contributed 'Tabbed Property View'. You can find more
information on it here:
http://www.eclipse.org/webtools/index.html
and the initial Web Tools contribution is here:
http://download.eclipse.org/webtools/downloads/initial-contr ibutions/ibm.zip
Cheers
Sean.
"bandrews" <none@bphnx.com> wrote in message
news:ch03b4$hbp$1@eclipse.org...
> thank you,
> B
Re: 2 Property views? [message #149112 is a reply to message #149081] Tue, 31 August 2004 04:26 Go to previous messageGo to next message
Sean probably meant to link to this:
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/TabbedPropertyEval.html?p=1
You can create as many views as you want, and thus as many properties views
as you want. Of course, nobody other than you is going to be contributing
to those views. IMO, it's better to keep all the properties together. If
the current view does not meet your needs, move everything to a custom view.
> thank you,
> B
Re: 2 Property views? [message #149156 is a reply to message #149112] Tue, 31 August 2004 12:51 Go to previous messageGo to next message
It's not better to keep all the properties together. I have view
properties and business properties. Why would I keep them together? It
doesn't make sense.
Thanks for the links! This will help. I will probably end up creating a
custom view.
thanks,
B
> > thank you,
> > B
Re: 2 Property views? [message #149170 is a reply to message #149156] Tue, 31 August 2004 13:15 Go to previous messageGo to next message
Originally posted by: gaslade.yahoo.com
Having a single view can make plenty of sense. IMHO Eclipse is suffering
from view bloat.... I get sick and tired of having to jump around 3 or 4
different views to do what I need to do.
In your case you could do something like a custom view that has a button
to flick between your business and view properties, or maybe show them
in a tree structure where there are two top level parents...view and
business.
Guy
> doesn't make sense.
> custom view.
> thanks,
> B
>>>thank you,
>>>B
Re: 2 Property views? [message #149183 is a reply to message #149170] Tue, 31 August 2004 13:19 Go to previous messageGo to next message
"In your case you could do something like a custom view that has a button
to flick between your business and view properties"
Ok, so what's the difference in having to click on a button and clicking
on a tab? In my opinion, clicking on a tab is much nicer looking.
"or maybe show them in a tree structure where there are two top level
parents"
Good idea!
> business.
> Guy
> > doesn't make sense.
> > custom view.
> > thanks,
> > B
view.
> >>>thank you,
> >>>B
Re: 2 Property views? [message #149245 is a reply to message #149183] Tue, 31 August 2004 17:44 Go to previous messageGo to next message
The difference is that the view tab does nothing when using all other types
of editors. Whereas the button would disappear when using other editors.
Why don't you just merge the two sets of properties together. Do you think
that the user has this mental model of business and view model separated?
You can also use categories in the propertysheet to separate the two.
news:ch1ttr$8sb$1@eclipse.org...
> parents"
> Good idea!
> > business.
> > Guy
> > > doesn't make sense.
a
> > > custom view.
> > > thanks,
> > > B
views
contributing
If
> view.
example, for
> > >>>thank you,
> > >>>B
Re: 2 Property views? [message #149266 is a reply to message #149245] Tue, 31 August 2004 18:24 Go to previous message
"Do you think that the user has this mental model of business and view
model separated?"
Absolutely! It all depends on your target audience. Have you ever looked
at Poseidon for UML? They do just that!
"You can also use categories in the propertysheet to separate the two."
Another good idea. Thanks!
> > parents"
> > Good idea!
> > > business.
> > > Guy
> > > > doesn't make sense.
> a
> > > > custom view.
> > > > thanks,
> > > > B
> views
> contributing
> If
> > view.
> example, for
> > > >>>thank you,
> > > >>>B
Previous Topic:Add many item in Logic
Next Topic:KeyListeners in ClassDiagram Using Draw2d
Current Time: Wed Feb 12 21:37:19 GMT 2025
Powered by FUDForum. Page generated in 0.03451 seconds
