Home » Eclipse Projects » GEF » 2 Property views?
2 Property views? [message #149081] |
Mon, 30 August 2004 20:40  |
Originally posted by: none.bphnx.com
Is is possible to create 2 properties views for a figure? For example, for
each figure I have a view model (size, location, etc.) and a business
model (business stuff), and I want to be able to change each models
attributes via 2 separate properties views. Is this possible?
thank you,
B
Re: 2 Property views? [message #149112 is a reply to message #149081] |
Tue, 31 August 2004 04:26   |
Sean probably meant to link to this:
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/TabbedPropertyEval.html?p=1
You can create as many views as you want, and thus as many properties views
as you want. Of course, nobody other than you is going to be contributing
to those views. IMO, it's better to keep all the properties together. If
the current view does not meet your needs, move everything to a custom view.
"bandrews" <none@bphnx.com> wrote in message
news:ch03b4$hbp$1@eclipse.org...
> thank you,
> B
Re: 2 Property views? [message #149156 is a reply to message #149112] |
Tue, 31 August 2004 12:51   |
It's not better to keep all the properties together. I have view
properties and business properties. Why would I keep them together? It
doesn't make sense.
Thanks for the links! This will help. I will probably end up creating a
custom view.
thanks,
B
> > thank you,
> > B
Re: 2 Property views? [message #149170 is a reply to message #149156] |
Tue, 31 August 2004 13:15   |
Originally posted by: gaslade.yahoo.com
Having a single view can make plenty of sense. IMHO Eclipse is suffering
from view bloat.... I get sick and tired of having to jump around 3 or 4
different views to do what I need to do.
In your case you could do something like a custom view that has a button
to flick between your business and view properties, or maybe show them
in a tree structure where there are two top level parents...view and
business.
Guy
> doesn't make sense.
> custom view.
> thanks,
> B
>>>thank you,
>>>B
Re: 2 Property views? [message #149183 is a reply to message #149170] |
Tue, 31 August 2004 13:19   |
"In your case you could do something like a custom view that has a button
to flick between your business and view properties"
Ok, so what's the difference in having to click on a button and clicking
on a tab? In my opinion, clicking on a tab is much nicer looking.
"or maybe show them in a tree structure where there are two top level
parents"
Good idea!
> business.
> Guy
> > doesn't make sense.
> > custom view.
> > thanks,
> > B
view.
> >>>thank you,
> >>>B
Re: 2 Property views? [message #149245 is a reply to message #149183] |
Tue, 31 August 2004 17:44   |
The difference is that the view tab does nothing when using all other types
of editors. Whereas the button would disappear when using other editors.
Why don't you just merge the two sets of properties together. Do you think
that the user has this mental model of business and view model separated?
You can also use categories in the propertysheet to separate the two.
news:ch1ttr$8sb$1@eclipse.org...
> parents"
> Good idea!
> > business.
> > Guy
> > > doesn't make sense.
a
> > > custom view.
> > > thanks,
> > > B
views
contributing
If
> view.
example, for
> > >>>thank you,
> > >>>B
Re: 2 Property views? [message #149266 is a reply to message #149245] |
Tue, 31 August 2004 18:24  |
"Do you think that the user has this mental model of business and view
model separated?"
Absolutely! It all depends on your target audience. Have you ever looked
at Poseidon for UML? They do just that!
"You can also use categories in the propertysheet to separate the two."
Another good idea. Thanks!
> > parents"
> > Good idea!
> > > business.
> > > Guy
> > > > doesn't make sense.
> a
> > > > custom view.
> > > > thanks,
> > > > B
> views
> contributing
> If
> > view.
> example, for
> > > >>>thank you,
> > > >>>B
Current Time: Thu Feb 13 13:47:30 GMT 2025
Powered by FUDForum. Page generated in 0.04177 seconds
