Home » Modeling » Papyrus » Papyrus install problems. And, what's needed for UML?
Papyrus install problems. And, what's needed for UML? [message #1021628] |
Wed, 20 March 2013 12:28 |
Toralf Lund Messages: 70 Registered: July 2009 |
Member |
Just tried to install "Papyrus Runtime" from
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/helios
on Eclipse Helios, but it failed with the below message. Any idea what is going on?
I tried "Papyrus all" as well, but with similar results. I did manage to install "Papyrus UML", on the other hand. This also sort of raises a few additional questions, like:
- What exactly do I need to install to be able to edit UML diagrams?
- Why isn't "Papyrus Runtime" already installed after a successful "Papyrus UML" install? I mean, you'd think that a "runtime" would be a prerequisite for other components, or possibly that the other components would be part of the runtime, but neither seems to be the case here (?)
- Does Eclipse component installation always have to be so darn confusing??
- Toralf
(Error output follows.)
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.epf.common,1.5.0.201101131810.
File has invalid content:/tmp/signatureFile382439104790505828.jar
Invalid content:common.jar
The file "common.jar" in the jar "/tmp/signatureFile382439104790505828.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.epf.common.html,1.5.0.201101131810.
File has invalid content:/tmp/signatureFile5549509020741295656.jar
Invalid content:lib/Tidy.jar
The file "lib/Tidy.jar" in the jar "/tmp/signatureFile5549509020741295656.jar" has been tampered!
Invalid content:commonHTML.jar
The file "commonHTML.jar" in the jar "/tmp/signatureFile5549509020741295656.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.epf.richtext,1.6.0.201101131810.
File has invalid content:/tmp/signatureFile193915286673543073.jar
Invalid content:richtext.jar
The file "richtext.jar" in the jar "/tmp/signatureFile193915286673543073.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.papyrus.diagram.common.palette.customization,0.7.3.v201104270854.
File has invalid content:/tmp/signatureFile4625254506578274974.jar
Invalid content:library.jar
The file "library.jar" in the jar "/tmp/signatureFile4625254506578274974.jar" has been tampered!
Re: Papyrus install problems. And, what's needed for UML? [message #1021677 is a reply to message #1021632] |
Wed, 20 March 2013 13:55 |
Member |
Federico Toledo wrote on Wed, 20 March 2013 08:35Hi,
I can say that I'm using Papyrus on Eclipse Juno, and the installation has no problems. Can you try to move to Juno?
I might, but was rather hoping I wouldn't have to right now, as I seem to spend way too much time on getting everything up and running whenever I switch versions.
Maybe I'm forced to switch, though, to get the features I need, as when I look a bit closer, I notice that the release that works on Helios has rather incomplete UML support. I really wish that Papyrus could be built in a more platform-independent manner:-/ Not sure if it's technically possible, though...
Just installing Papyrus you can create and edit UML models
good luck!!
What I was driving at, is that there isn't seems to be one obvious way to "just install Papyrus", since there are at least 3 different "top-level" packages. But maybe that's different with newer releases?
Re: Papyrus install problems. And, what's needed for UML? [message #1021682 is a reply to message #1021677] |
Wed, 20 March 2013 14:01 |
Ed Willink Messages: 7655 Registered: July 2009 |
Yes. It would be great not to have irritating progress such as fire,
wheels and telephones.
Juno gives you UML 2.4.1; enjoy.
Ed Willink
> Quote:
>> good luck!!
Re: Papyrus install problems. And, what's needed for UML? [message #1022107 is a reply to message #1021682] |
Thu, 21 March 2013 09:38 |
Member |
Ed Willink wrote on Wed, 20 March 2013 10:01Hi
Yes. With any luck, though, "progress" will soon rid us of silly notions like being able to put improved variants of those wheels on a car without replacing the entire wehicle first...
Ed Willink
Current Time: Fri Mar 29 15:04:29 GMT 2024
Powered by FUDForum. Page generated in 0.02969 seconds
