Re: CVS - src/bin [message #14650 is a reply to message #13880] |
Tue, 06 May 2003 08:18 |
Originally posted by: daniel.megert.gmx.net
jda wrote:
> I've set new project parameters to have source and output locations of
> src and bin, respectively.
> (Windows -> Preferences -> New Project -> folders)
> However, when I Checkout as... from the CVS repository perspective,
> it does not create these divisions?
> How can I accomplish this?
You can't. There's no transformation support upon checkout. If you
checkout non-eclipse source from an existing CVS repository I suggest to
use "Check Out As..." which allows you to setup the Java build path upon
checkout.
HTH
Dani
Re: CVS - src/bin [message #15091 is a reply to message #15077] |
Tue, 06 May 2003 17:39 |
Is there any reason why you can't check the .classpath and .project back
into CVS? It would simplify things tremendously. You won't need to do
Checkout As... It would know automatically the type of project it is.
Rich Kulp
Re: CVS - src/bin [message #15824 is a reply to message #15805] |
Tue, 06 May 2003 19:52 |
IT sounds like the easiest thing is to Check it out, update the
source/bin paths to what you want, and then check them in.
Rich
FUDForum. Page generated in 0.03403 seconds
