Timeout Exception [message #1021197] |
Tue, 19 March 2013 16:35 |
Krishna T Messages: 4 Registered: March 2013 |
Hi, I have developed a plug-in which communicates to Server using TCP/IP. I am getting the data perfectly, the problem is after reading all the data SocketTimeout exception is raised and going to catch block.
I have increased the SocketTimeout value too, but still no use.
Can any one help me? I am placing Trace of the exception.
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at sun.nio.cs.StreamDecoder.readBytes(Unknown Source)
at sun.nio.cs.StreamDecoder.implRead(Unknown Source)
at sun.nio.cs.StreamDecoder.read(Unknown Source)
at java.io.InputStreamReader.read(Unknown Source)
at java.io.BufferedReader.fill(Unknown Source)
at java.io.BufferedReader.read(Unknown Source)
at com.infotech.debugger.util.ClientCommunication.startCommunication(ClientCommunication.java:89)
at com.infotech.debugger.dialog.StartConditionsDialog.startCommunication(StartConditionsDialog.java:894)
at com.infotech.debugger.dialog.StartConditionsDialog.access$9(StartConditionsDialog.java:817)
at com.infotech.debugger.dialog.StartConditionsDialog$7.widgetSelected(StartConditionsDialog.java:501)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.infotech.debugger.actions.StartDebugger.execute(StartDebugger.java:54)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
[Updated on: Tue, 19 March 2013 16:42] Report message to a moderator
Re: Timeout Exception [message #1021511 is a reply to message #1021221] |
Wed, 20 March 2013 08:55 |
the following is the code i have written, Some one can identify the problem in the below code for TimeoutException.
try {
if(echoSocket == null)
echoSocket = new Socket(hostAddress, serverPort);
if(echoSocket.getInetAddress() != null)
out = new PrintWriter(echoSocket.getOutputStream(), true);
String userInput=command.concat(" \r") ;
out.println(userInput);
out.flush();
echoSocket.setSoTimeout(timeout);
br = new BufferedReader(new InputStreamReader(echoSocket.getInputStream()));
responseLine = "";
while((value = br.read()) != -1)
char c = (char)value;
responseLine = responseLine + c;
[Updated on: Wed, 20 March 2013 09:35] Report message to a moderator
FUDForum. Page generated in 0.03311 seconds
