Home » Modeling » OCL » Build an OCL AST - Set OperationCallExp{source,argument,name}
Build an OCL AST - Set OperationCallExp{source,argument,name} [message #1020971] |
Tue, 19 March 2013 09:18 |
Eugen Kuksa Messages: 2 Registered: March 2013 |
I'm trying to generate an OCL AST with org.eclipse.ocl.ecore.EFactory, but I cannot find a way to create an OperationCallExp. Also I cannot find any good documentation about that topic.
I'm currently interested in the String output of the OCL constraints I generate. The constraints are supposed to be related to an ecore model. Later, I want to save the constraints in an OCL file. Thus, it is important to have the AST.
As for the beginning, I made a Unit Test to get used to the API:
def void testExpressions() {
var lnull = factory.createNullLiteralExp
assertEquals("null", lnull.toString)
var lbool = factory.createBooleanLiteralExp
lbool.booleanSymbol = true
assertEquals("true", lbool.toString)
lbool.booleanSymbol = false
assertEquals("false", lbool.toString)
var lint = factory.createIntegerLiteralExp
lint.integerSymbol = 1234
assertEquals("1234", lint.toString)
var lreal = factory.createRealLiteralExp
lreal.realSymbol = 1.234
assertEquals("1.234", lreal.toString)
var lif = factory.createIfExp
lif.condition = lbool
lif.thenExpression = lint
lif.elseExpression = lreal
assertEquals("if false then 1234 else 1.234 endif", lif.toString)
The next step would be to create OperationCallExps, but there's no way to set the operation name, the source, the infix-flag and the arguments.
I'm using org.eclipse.ocl version 4.0.2
Re: Build an OCL AST - Set OperationCallExp{source,argument,name} [message #1021056 is a reply to message #1020971] |
Tue, 19 March 2013 12:53 |
Ed Willink Messages: 7655 Registered: July 2009 |
There is no org.eclipse.ocl.ecore.EFactory.
There is a org.eclipse.ocl.ecore.EcoreFactory which has a
createOperationCallExp()
I presume you are getting confused with org.eclipse.emf.ecore.EcoreFactory.
Creating OCL ASTs programmatically is seriously hard. I suggest you
review your entire design approach and consisder using the available
text to AST facilities, possibly using the new Pivot-based epresentation
that provides a PrettyPrintVisitor as well as a ToStringVisitor.
Ed Willink
On 19/03/2013 12:18, Eugen Kuksa wrote:
Re: Build an OCL AST - Set OperationCallExp{source,argument,name} [message #1021206 is a reply to message #1021056] |
Tue, 19 March 2013 16:53 |
Ed Willink wrote on Tue, 19 March 2013 08:53
You're right. That was a typo. I actually use org.eclipse.ocl.ecore.EcoreFactory.
Thanks for the hint, but I see the difference between those two (and I use both in my project).
Is there really no usable way to generate the AST? For some of the OCL features it already works perfectly fine, as can be seen in my initial post.
My approach is to create the AST and then create text from that, not the other way around. The textual representation of OCL is supposed to be the final result of my project. I don't want to do any calculations on the AST - only output a concrete syntax representation.
Re: Build an OCL AST - Set OperationCallExp{source,argument,name} [message #1021222 is a reply to message #1021206] |
Tue, 19 March 2013 17:20 |
> post.
The AST is an EMF-generated model so you can fully construct it in Java
and may find some utility routines to help you a bit.
However there are many subtleties such as ownership of synthesized
collection types and references to library operations.
Ultimately you should be aware that, as specified, the OMG AST is
unimplementable.
The classic Ecore/UML-based ASTs are propretary with unpleasant templates.
The new Pivot-based AST could be regarded as a prototype for resolution
of the problems in OCL 2.5, however it is used internally and saved for
debug; it is not yet consistently loadable.
If you really want to do programmatic construction, I recommend define a
richer Factory with methods such as
createIfExp(condExp, thenExp, elseExp)
createCollectionType(kind, elementType)
so that your calling code will be moderately readable and
rationalization of the AST will be substantially hidden.
Such a Facade could make for a useful addition to the Eclipse OCL
project. It bears some resemblance to ValuesUtil and
DomainStandardLibrary in the new code.
Ed Willink
Current Time: Thu Apr 25 15:47:52 GMT 2024
Powered by FUDForum. Page generated in 0.04008 seconds
