Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Problem calling AcceleoService programatically
icon4.gif  [Acceleo] Problem calling AcceleoService programatically [message #1020941] Tue, 19 March 2013 08:26 Go to next message
Marc Schlegel is currently offline Marc SchlegelFriend
Member
Hello everyone,
I am going to hold a little informal presentation for my company about M2T-Generators. Since I only used xText with xPand, I thought it would be a good idea to show some alternatives as well so I dove into Acceleo yesterday.
I think I got everything setup, but there must be still a little mistake. I created a project with the mtl-files and a Workflow-class (AbstractAcceleoGenerator) which is exported. The project is included in my ECore-Editor-project and the Command is calling the workflow.
I attached my template-modules, and this is how I call the Generator
Workflow wf = new Workflow(
	URI.createFileURI(editorInput.getFullPath().toString()),
	folder.getFullPath().toFile(),
	Collections.emptyList());
wf.doGenerate(new BasicMonitor());
But nothing happens...so I debugged into it. Withing the AcceleoService#doGenerate there is a loop which traverses over my ECore-Model
while (targetElements.hasNext()) {
	final EObject potentialTarget = targetElements.next();
	if (argumentType.isInstance(potentialTarget)) {
		final List<Object> actualArguments = new ArrayList<Object>();
		actualArguments.add(potentialTarget);
		actualArguments.addAll(arguments);
		previewResult.putAll(doGenerateTemplate(template, actualArguments, generationRoot,
				monitor));
		generationHasOccurred = true;
This is the problem
because it is never true.
argumentType is always EClassifier whereas potentialTarget is a Class from my ECore (which seems correct to me). So I guess I have to tell Acceleo that the starting-point is a of a certain type from my model (in this case DTOs).
Can someone help me out please and show me what I am missing?
  • Attachment: workflow.mtl
    (Size: 0.21KB, Downloaded 160 times)
  • Attachment: javaBeans.mtl
    (Size: 0.74KB, Downloaded 145 times)
Re: [Acceleo] Problem calling AcceleoService programatically [message #1021080 is a reply to message #1020941] Tue, 19 March 2013 13:53 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane BegaudeauFriend
If you launch the generation do you have any kind of error message (package not registered, resource factory missing)?
Do the value argument type or the value potentialTarget are proxy (eIsProxy())?
Are you launching the generator in Eclipse (as an Eclipse plug-in deployed in an Eclipse instance) or as a stand alone Java application (EMFPlugin.IS_ECLIPSE_RUNNING)?
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: [Acceleo] Problem calling AcceleoService programatically [message #1021162 is a reply to message #1021080] Tue, 19 March 2013 15:33 Go to previous messageGo to next message
Member
No, I do not get any error messages, thats why I assumed that the template-configuration is correct.
There are also no eIsProxy-attributes.
But I just saw a slight mistake in my first post: argumentType is an EClassImpl with the attribute name set to DTOs. So I guess this is the argument from my template.
The first portentialTarget is an instance of BeanImpl which is confusing...
My ECore-Tree looks like this.
DTOs (has a containment of beans)
	BeanA (has a containment of properties)
		Property1
		Property2
	BeanB
So I am wondering why the doGenerate starts traversing with the Beans instead with DTOs
Re: [Acceleo] Problem calling AcceleoService programatically [message #1021661 is a reply to message #1021162] Wed, 20 March 2013 13:26 Go to previous messageGo to next message
ArgumentType should be the type of the parameter of your main template, the potential target is an element of your model. We first try with the root of your model and then we all its content:
// The input model itself is a potential argument
if (argumentType.isInstance(model)) {
	actualArguments.add(model);
	previewResult.putAll(doGenerateTemplate(template, actualArguments, generationRoot, monitor));
final TreeIterator<EObject> targetElements = model.eAllContents();
With the ecore tree that you have described, for some reasons this "argumentType.isInstance(model)" returns false. What version of Acceleo are you using and where is your meta-model located (in another project in the workspace, in a plug-in)?
Re: [Acceleo] Problem calling AcceleoService programatically [message #1021749 is a reply to message #1021661] Wed, 20 March 2013 16:05 Go to previous message
Member
Stephane Begaudeau wrote on Wed, 20 March 2013 09:26
Hi, I am using the Juno-ReleaseTrain-Version: 3.3.2
But your point about the plugin-structure might be the right hint. This is how it looks
  • simplegenerator (here is the ecore and the generated Java-model-classes)
  • simplegenerator.edit
  • simplegenerator.editor (from here I call Acceleo -> dependecy on simplegenerator.acceleo)
  • simplegenerator.acceleo
Still, when I add a dependency to simplgenerator for simplegenerator.acceleo I still have the same problem.
I attached my little testproject. I hold the presentation today so it is not important any more, but still I´d like to solve the issue to dive deeper into the framework.
Previous Topic:Xpand Workflow file
Next Topic:[Acceleo] Simple, step by step, working tutorial, from UML to code?
Current Time: Wed Oct 27 14:32:25 GMT 2021
Powered by FUDForum. Page generated in 0.02106 seconds
