Re: unresolved inclusions [message #1020987 is a reply to message #1020724] |
Tue, 19 March 2013 09:58 |
Quote:"unresolved inclusion <library file>"
This means that the library file could not be found.
You have to set the pathes in project/properties/C/C++ include pathes and symbols
Niko
Eclipse-CDT Version: 2019-12 (4.14.0), Win10 64bit
Re: unresolved inclusions [message #1021211 is a reply to message #1020987] |
Tue, 19 March 2013 17:10 |
sydney faria Messages: 54 Registered: March 2013 |
Member |
I have 10 projects created, all from the Eckel book, and this is the only project that shows this error about the include files not found. If I go into the Project/Properties/C/C++ Build menu and look at the environment I see CWD, PWD, & PATH variables set up and especially the PATH is set to C:/minGW/bin directory so it looks like the compiler/linker should find the library files! Also C/C++ General/Paths and Symbols/Languages/GNU C has C:/minGW/include in there and so does the Preprocessor Include Paths contain C:/mingw/include! So I think this is not the problem, but again I can't find a solution.
[Updated on: Tue, 19 March 2013 17:12] Report message to a moderator
FUDForum. Page generated in 0.01748 seconds
